[QGIS-Developer] DWG/DXF QGIS on Linux/Debian
Frank Broniewski broniewski at a-a.lu
Thu Jul 13 00:25:03 PDT 2023
I believe you still can, but your DWG file version is too new. Try to save your DWG as an older version (ie 10 or 13) and it should work.
-----Ursprüngliche Nachricht-----
Von: QGIS-Developer <qgis-developer-bounces at lists.osgeo.org> Im Auftrag von Matteo Ghetta via QGIS-Developer
Gesendet: Donnerstag, 13. Juli 2023 09:10
An: qgis-developer at lists.osgeo.org
Betreff: [QGIS-Developer] DWG/DXF QGIS on Linux/Debian
Hi all,
I'm on a Debian testing fresh machine and with both QGIS 3.28 from package and master compiled I cannot import DWG/DXF. This is the error I
get:
Drawing import failed (unsupported version. Cannot read AutoCAD
2018/2019/2020 documents.)
I don't remember if there is a procedure on Linux (Debian) to compile QGIS with a driver that allows to import those formats.
Thanks for any suggestion!
Matteo
QGIS-Developer mailing list
QGIS-Developer at lists.osgeo.org
List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
More information about the QGIS-Developer mailing list
