[QGIS-Developer] DWG/DXF QGIS on Linux/Debian
Johannes Kröger (WhereGroup)
johannes.kroeger at wheregroup.com
Thu Jul 13 00:31:22 PDT 2023
Hi Matteo,
I assume that those are provided via GDAL. Check
https://gdal.org/drivers/vector/ for how to get a GDAL that supports them.
https://gdal.org/drivers/vector/cad.html sounds like you need to make
sure that your GDAL was compiled with its internal libopencad or you
could use https://gdal.org/drivers/vector/oda.html
Good luck!
Hannes
Am 13.07.23 um 09:10 schrieb Matteo Ghetta via QGIS-Developer:
> Hi all,
> I'm on a Debian testing fresh machine and with both QGIS 3.28 from
> package and master compiled I cannot import DWG/DXF. This is the error
> I get:
> Drawing import failed (unsupported version. Cannot read AutoCAD
> 2018/2019/2020 documents.)
> I don't remember if there is a procedure on Linux (Debian) to compile
> QGIS with a driver that allows to import those formats.
> Thanks for any suggestion!
> Matteo
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Johannes Kröger / GIS-Entwickler/-Berater
Aufwind durch Wissen!
Web-Seminare und Online-Schulungen
bei der www.foss-academy.com
WhereGroup GmbH
c/o KK03 GmbH
Lange Reihe 29
20099 Hamburg
Germany
Tel: +49 (0)228 / 90 90 38 - 36
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Geschäftsführer:
Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRB 9885
