[QGIS-Developer] DWG/DXF QGIS on Linux/Debian
Matteo Ghetta
matteo.ghetta at gmail.com
Thu Jul 13 01:05:41 PDT 2023
thanks for all the answers!
I forgot to tell the those files are importable in Windows. Does it
change anything?
Matteo
On 7/13/23 09:59, Matthias Kuhn wrote:
> Hi Matteo,
> libdxfrw doesn't support this version yet.
> There's an open PR for libdxfrw for importing newer versions:
> https://github.com/LibreCAD/libdxfrw/pull/63
> <https://github.com/LibreCAD/libdxfrw/pull/63>
> You might be able to manually patch it if you are adventurous
> Matthias
> On Thu, Jul 13, 2023 at 9:44 AM Stefan Giese (WhereGroup) via
> QGIS-Developer <qgis-developer at lists.osgeo.org
> <mailto:qgis-developer at lists.osgeo.org>> wrote:
> Hi Matteo,
> did you import via drag-and-drop from the Browser or did you use use
> the dedicated Project ► Import/Export ► Import Layers from DWG/DXF tool?
> Best Stefan
> Am 13.07.2023 um 09:10 schrieb Matteo Ghetta via QGIS-Developer:
>> Hi all,
>> I'm on a Debian testing fresh machine and with both QGIS 3.28 from
>> package and master compiled I cannot import DWG/DXF. This is the
>> error I get:
>> Drawing import failed (unsupported version. Cannot read AutoCAD
>> 2018/2019/2020 documents.)
>> I don't remember if there is a procedure on Linux (Debian) to
>> compile QGIS with a driver that allows to import those formats.
>> Thanks for any suggestion!
>> Matteo
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> <mailto:QGIS-Developer at lists.osgeo.org>
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> <https://lists.osgeo.org/mailman/listinfo/qgis-developer>
>> Unsubscribe:
> Mit freundlichen Grüßen
> Stefan Giese
> Projektleiter/Consultant
> Aufwind durch Wissen!
> Web-Seminare und Online-Schulungen
> bei derwww.foss-academy.com <http://www.foss-academy.com>
> WhereGroup GmbH
> Schwimmbadstr. 2
> 79100 Freiburg
> Germany
> Tel.: +49 (0)761 / 519 102 - 61
> Fax: +49 (0)761 / 519 102 - 11
> stefan.giese at wheregroup.com <mailto:stefan.giese at wheregroup.com>
> www.wheregroup.com <http://www.wheregroup.com>
> Geschäftsführer:
> Olaf Knopp, Peter Stamm
> Amtsgericht Bonn, HRB 9885
> QGIS-Developer at lists.osgeo.org <mailto:QGIS-Developer at lists.osgeo.org>
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
