[QGIS-Developer] DWG/DXF QGIS on Linux/Debian
Matthias Kuhn
matthias at opengis.ch
Thu Jul 13 00:59:13 PDT 2023
Hi Matteo,
libdxfrw doesn't support this version yet.
There's an open PR for libdxfrw for importing newer versions:
https://github.com/LibreCAD/libdxfrw/pull/63
You might be able to manually patch it if you are adventurous
Matthias
On Thu, Jul 13, 2023 at 9:44 AM Stefan Giese (WhereGroup) via
QGIS-Developer <qgis-developer at lists.osgeo.org> wrote:
> Hi Matteo,
> did you import via drag-and-drop from the Browser or did you use use the
> dedicated Project ► Import/Export ► Import Layers from DWG/DXF tool?
> Best Stefan
> Am 13.07.2023 um 09:10 schrieb Matteo Ghetta via QGIS-Developer:
> Hi all,
> I'm on a Debian testing fresh machine and with both QGIS 3.28 from package
> and master compiled I cannot import DWG/DXF. This is the error I get:
> Drawing import failed (unsupported version. Cannot read AutoCAD
> 2018/2019/2020 documents.)
> I don't remember if there is a procedure on Linux (Debian) to compile QGIS
> with a driver that allows to import those formats.
> Thanks for any suggestion!
> Matteo
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Mit freundlichen Grüßen
> Stefan Giese
> Projektleiter/Consultant
> Aufwind durch Wissen!
> Web-Seminare und Online-Schulungen
> bei der www.foss-academy.com
> WhereGroup GmbH
> Schwimmbadstr. 2
> 79100 Freiburg
> Germany
> Tel.: +49 (0)761 / 519 102 - 61
> Fax: +49 (0)761 / 519 102 - 11
> stefan.giese at wheregroup.comwww.wheregroup.com
> Geschäftsführer:
> Olaf Knopp, Peter Stamm
> Amtsgericht Bonn, HRB 9885
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20230713/f2c5d0e2/attachment.htm>
