[QGIS-Developer] DWG/DXF QGIS on Linux/Debian
Stefan Giese (WhereGroup)
stefan.giese at wheregroup.com
Thu Jul 13 00:44:27 PDT 2023
Hi Matteo,
did you import via drag-and-drop from the Browser or did you use use the
dedicated Project ► Import/Export ► Import Layers from DWG/DXF tool?
Best Stefan
Am 13.07.2023 um 09:10 schrieb Matteo Ghetta via QGIS-Developer:
> Hi all,
> I'm on a Debian testing fresh machine and with both QGIS 3.28 from
> package and master compiled I cannot import DWG/DXF. This is the error
> I get:
> Drawing import failed (unsupported version. Cannot read AutoCAD
> 2018/2019/2020 documents.)
> I don't remember if there is a procedure on Linux (Debian) to compile
> QGIS with a driver that allows to import those formats.
> Thanks for any suggestion!
> Matteo
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Mit freundlichen Grüßen
Stefan Giese
Projektleiter/Consultant
Aufwind durch Wissen!
Web-Seminare und Online-Schulungen
bei derwww.foss-academy.com
WhereGroup GmbH
Schwimmbadstr. 2
79100 Freiburg
Germany
Tel.: +49 (0)761 / 519 102 - 61
Fax: +49 (0)761 / 519 102 - 11
www.wheregroup.com
Geschäftsführer:
Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRB 9885
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20230713/c375ef71/attachment-0001.htm>
