[QGIS-Developer] How to see queries sent to GPKG layer for debugging
Vedran Stojnović phidrho at gmail.com
Tue Jul 25 23:50:17 PDT 2023
I just figured out it already works, I've had layers with identical layers
names in all three data sources so I thought it was from the same layer...
Sorry.
sri, 26. srp 2023. u 08:35 Vedran Stojnović <phidrho at gmail.com> napisao je:
> Hi Alessandro,
> thank you for this feature, and now that's implemented I can better track
> bugs.
> Now that's been implemented in QGIS for the GPKG layers and is working
> well, can we extend this feature to SpatiaLite and raw "SQLite" layers too,
> all of these are based on SQLite DB?
> Should this be a QGIS feature request or a GDAL feature request?
> pon, 19. pro 2022. u 13:37 Alessandro Pasotti <apasotti at gmail.com>
> napisao je:
>> I don't, sorry.
>> On Mon, Dec 19, 2022 at 1:07 PM Vedran Stojnović <phidrho at gmail.com>
>> wrote:
>> > Hi Alessandro,
>> > thank you very much for info.
>> > Do you maybe know any workaround for this in the meanwhile?
>> > One of my coworkers is currently on hold because of this.
>> > pon, 19. pro 2022. u 12:33 Alessandro Pasotti <apasotti at gmail.com>
>> napisao je:
>> >> It's coming: see https://github.com/OSGeo/gdal/pull/6837
>> >> On Mon, Dec 19, 2022 at 12:28 PM Vedran Stojnović via QGIS-Developer
>> >> <qgis-developer at lists.osgeo.org> wrote:
>> >> > Hi,
>> >> > I am trying to find source of some bug related to data input via
>> form.
>> >> > I have set up some triggers in DB which are not executed if data is
>> edited through QGIS, but if I change manually in SQLite than it works as
>> expected.
>> >> > How can I see what queries are sent to GPKG database?
>> >> > I tried to open Debugging/Development Tools Panel and enabled
>> "Record Log" but nothing is shown there.
>> >> > Kind regards,
>> >> > Vedran Stojnović.
>> >> > _______________________________________________
>> >> > QGIS-Developer mailing list
>> >> > QGIS-Developer at lists.osgeo.org
>> >> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> >> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> >> Alessandro Pasotti
>> >> QCooperative:  www.qcooperative.net
>> >> ItOpen:   www.itopen.it
>> > Srdačan pozdrav,
>> > Vedran Stojnović.
>> Alessandro Pasotti
> Srdačan pozdrav / Kind regards,
> Vedran Stojnović.
Vedran Stojnović.
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20230726/402e9010/attachment.htm>
More information about the QGIS-Developer mailing list
