[QGIS-Developer] Re-discussing the QGIS release schedule - in combination with the quarantine rule for LTR versions
Andreas Neumann a.neumann at carto.net
Wed Mar 1 01:23:52 PST 2023
Like that other decision - that was a bit hard to find (you helped me
find it in QEP 239) - I don't know exactly where the quarantine rule
originated. I am pretty sure there was discussion.
Nyall: can you please share some background when and why it was
introduced and if this decision can be found in some QEP or PSC
decision?
Note that I am not questioning the quarantine rule - I think it makes
sense - but I want to discuss the combination of the quarantine rule
with the thinned out release cycle - and how we can improve things in
this respect.
Thank you all for the discussion,
Andreas
On 2023-03-01 10:16, Jürgen E. Fischer via QGIS-Developer wrote:
> Hi Andreas,
> On Tue, 28. Feb 2023 at 08:55:49 +0100, Andreas Neumann via
>> However, the situation is, that there is also a "quarantine rule" -
>> which
>> is not mentioned in QEP 239 - but it helps to prevent untested patches
>> to
>> end up in LTR versions, by delaying the backports until the backport
>> was
>> first tested in the non-LTR stable release.
> Where is that quarantine rule?  Is it tied into the backport bot?
> In the good old days I'd apply my fixes to master also to the release
> branches,
> once the showed to work in master and didn't produce additional
> complains from
> users of the nightlies.  And that ideally not shortly before the
> release so
> people could still try the release nightlies.
> Jürgen
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20230301/69f41688/attachment.htm>
More information about the QGIS-Developer mailing list
