[QGIS-Developer] Release 3.30 delayed
Jürgen E. Fischer
jef at norbit.de
Fri Mar 3 07:15:04 PST 2023
Hi Andreas,
On Fri, 03. Mar 2023 at 15:59:44 +0100, Andreas Neumann via QGIS-Developer wrote:
> > > the apostrophe in the new release name was a little issue, but there's
> > > another issue with transifex: for some reason the spanish translation
> > > dropped below 35% and would be removed…
> We can always use "Den Bosch" - if that other name causes too many troubles
"was" is past tense - so that's sorted out (not pushed yet though). And I
doubt that changing the release name would help with transifex ;)
The problem is that the spanish translation should be above 80%, but shows at
19% and is therefore automatically removed when pulling in the transifex update
into the new branch.
On the transifex side there are tons of translations that have a 101%
suggestion - which means that they match a previous translation that transifex
still has in memory - it apparently "just" lost, that that' the current
translation.
Not sure what happened and why it only affects the spanish translation - the
others seem ok.
Sandy from transifex support just replied, that she's going to take this to the
engineers for a closer look and keep me posted. hm.
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden https://www.norbit.de
QGIS release manager (PSC) Germany IRC: jef on Libera|OFTC
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20230303/73bd688c/attachment.sig>
