[QGIS-Developer] Problem with creating EXE aplikation PyQGIS
office at kanet.sk
office at kanet.sk
Mon Mar 20 02:50:12 PDT 2023
Hallo,
I have a larger application, just this small test, I'm trying pyinstaller.
I am testing a simple PyQgis application. When I add the line "from
qgis.core import QgsApplication" and make an exe via pyinstaller, the
application crashes with an error:
When I comment out the line "from qgis.core import QgsApplication" the
application window starts normally after creating the EXE.
See Code:
import sys
from qgis.PyQt.QtWidgets import QApplication, QMainWindow, QWidget,
QHBoxLayout, QLabel
class MainWindow(QMainWindow):
def __init__(self, parent=None):
super(MainWindow, self).__init__(parent)
self.setWindowTitle("Mapová prezeračka --- Pebieha načítanie dát
self.init_gui()
self.show()
def init_gui(self):
self.formular = QWidget()
layoutFormulara = QHBoxLayout()
self.formular.setLayout(layoutFormulara)
boxLayout1 = QHBoxLayout()
boxLayout2 = QHBoxLayout()
layoutFormulara.addStretch()
layoutFormulara.addLayout(boxLayout1)
layoutFormulara.addLayout(boxLayout2)
self.label1 = QLabel("Hello")
boxLayout1.addWidget(self.label1)
self.setCentralWidget(self.formular)
def main():
# vytvoriť hlavné okno
mainWin = MainWindow()
mainWin.show()
# Run aplikáciu
try:
retval = app.exec_()
# Exit aplication
sys.exit(retval) # this will always trigger SystemExit
except SystemExit:
print("sys.exit() it worked as expected ")
except:
print("Something has gone terribly wrong ") # another exception was
raised
if __name__ == "__main__":
app = QApplication(sys.argv)
main()
I looked for many answers on the Internet but I couldn't find anything.
I've read the pyinstaller manual, I'm just new to this. I am sending a
TestEXE.spec file.
Pripájam file spec.
import os
block_cipher = None
workdir = os.getenv('VIEWER_DIR')
a = Analysis(['main.py'],
pathex=[workdir],
binaries=None,
datas=[(os.path.join(workdir,'testdata/*'),'testdata'),
(os.path.join(workdir,'qgis_plugins/*'),'qgis_plugins'),
(os.path.join(workdir,'graphics/*'),'graphics'),],
hiddenimports=['qgis.PyQt.QtWidgets','qgis.core.QgsApplication']
hookspath=None,
runtime_hooks=None,
excludes=None,
win_no_prefer_redirects=None,
win_private_assemblies=None,
cipher=block_cipher)
pyz = PYZ(a.pure, a.zipped_data,
exe = EXE(pyz,
a.scripts,
exclude_binaries=True,
name='TestEXE',
debug=True,
bootloader_ignore_signals=False,
strip=False,
upx=True,
console=False ,
icon='graphics/airports.ico')
coll = COLLECT(exe,
a.binaries,
a.zipfiles,
a.datas,
strip=False,
upx=True,
upx_exclude=[],
name='TestEXE')
Thank you very much in advance for your help.
Kind regards / Spozdravom
Ing. Stanislav Klanduch
firm owner
KAnet soft-net services
Kuzmányho 902
01701 Považská Bystrica
Slovakia (SK)
tel: +421 6504 07170
mobil: +421 918 394 876
fax: +421 6504 07170
mail: <mailto:office at kanet.sk> office at kanet.sk
web: <http://www.kanet.sk> www.kanet.sk
P Pred vytlacením tohto mailu prosím zvážte dopad na životné prostredie.
Dakujeme. / Please consider the environment before printing this e-mail.
Thanks.
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20230320/d7dc8afc/attachment-0001.htm>
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20230320/d7dc8afc/attachment-0002.obj>
Type: text/x-python
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20230320/d7dc8afc/attachment-0001.py>
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20230320/d7dc8afc/attachment-0003.obj>
