[QGIS-Developer] Tool to create Mesh from raster layer?
Stefan Giese (WhereGroup) stefan.giese at wheregroup.com
Mon Mar 20 06:20:51 PDT 2023
Hi all,
I think it is not nessasary to go through Blender, just use theese two
algorithm:
  * pixeltopoints
  * tinmeshcreation
Best regards
Stefan
Am 20.03.2023 um 14:11 schrieb Sebastian Gutwein via QGIS-Developer:
> The ridiculous work around I use is to go through Blender using the
> BlenderGIS plugin. Import the raster into Blender as a new mesh >
> Decimate the mesh > Export as a shapefile > Run TIN Mesh Creation in
> QGIS.
> On Mon, Mar 20, 2023 at 9:03 AM Saber Razmjooei via QGIS-Developer
> <qgis-developer at lists.osgeo.org> wrote:
>     Hi Andreas,
>     There should be a tool to convert vector to mesh (under Processing
>     > Mesh > TIN Mesh Creation). There will also be some new
>     Processing tools for handling point clouds. But I am not aware of
>     any Raster > Mesh tools.
>     Kind regards
>     Saber
>     On Mon, 20 Mar 2023 at 13:56, Andreas Neumann via QGIS-Developer
>         Hi QGIS devs,
>         Is there a tool available to create a Mesh (or TIN as a
>         special mesh variation) from a source raster layer containing
>         terrain values?
>         I did not find one - but maybe I didn't look everywhere.
>         If not in QGIS - do you know an external Open Source tool that
>         could do that, while keeping real world coordinates?
>         Thanks,
>         Andreas
>         _______________________________________________
>         QGIS-Developer mailing list
>         QGIS-Developer at lists.osgeo.org
>         List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>         Unsubscribe:
>     Saber Razmjooei
>     www.lutraconsulting.co.uk <http://www.lutraconsulting.co.uk>
>     +44 (0)7568 129733
>     Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Sebastian "Bas* " Gutwein
> *rhymes with Josh
> Regenerative Design Group
> 1 Chevalier Ave
> Greenfield, Ma 01301
> Web: regenerativedesigngroup.com <http://regenerativedesigngroup.com>
> (631) 241-1018
> /Look close, think big, make change. /
> List info:https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-developer
Mit freundlichen Grüßen
Stefan Giese
Projektleiter/Consultant
FOSSGIS Konferenz
15.-18. März 2023 in Berlin
https://fossgis-konferenz.de/2023/
WhereGroup-Beiträge auf der FOSSGIS
https://wheregroup.com/unternehmen/aktuelles/
WhereGroup GmbH
Schwimmbadstr. 2
79100 Freiburg
Germany
Tel.: +49 (0)761 / 519 102 - 61
Fax: +49 (0)761 / 519 102 - 11
www.wheregroup.com
Geschäftsführer:
Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRB 9885
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20230320/0c2697b5/attachment-0001.htm>
More information about the QGIS-Developer mailing list
