[QGIS-Developer] Tool to create Mesh from raster layer?
Sebastian Gutwein
bas at rdgland.com
Mon Mar 20 06:11:02 PDT 2023
The ridiculous work around I use is to go through Blender using the
BlenderGIS plugin. Import the raster into Blender as a new mesh > Decimate
the mesh > Export as a shapefile > Run TIN Mesh Creation in QGIS.
On Mon, Mar 20, 2023 at 9:03 AM Saber Razmjooei via QGIS-Developer <
qgis-developer at lists.osgeo.org> wrote:
> Hi Andreas,
> There should be a tool to convert vector to mesh (under Processing > Mesh
> > TIN Mesh Creation). There will also be some new Processing tools for
> handling point clouds. But I am not aware of any Raster > Mesh tools.
> Kind regards
> Saber
> On Mon, 20 Mar 2023 at 13:56, Andreas Neumann via QGIS-Developer <
>> Hi QGIS devs,
>> Is there a tool available to create a Mesh (or TIN as a special mesh
>> variation) from a source raster layer containing terrain values?
>> I did not find one - but maybe I didn't look everywhere.
>> If not in QGIS - do you know an external Open Source tool that could do
>> that, while keeping real world coordinates?
>> Thanks,
>> Andreas
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Saber Razmjooei
> www.lutraconsulting.co.uk
> +44 (0)7568 129733
Sebastian "Bas* " Gutwein
*rhymes with Josh
Regenerative Design Group
1 Chevalier Ave
Greenfield, Ma 01301
Web: regenerativedesigngroup.com
(631) 241-1018
*Look close, think big, make change. *
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20230320/4c287965/attachment.htm>
