[QGIS-Developer] How does QGIS parses the shapefile so quickly
Even Rouault even.rouault at spatialys.com
Mon Mar 27 08:15:21 PDT 2023
Le 27/03/2023 à 10:06, Alessandro Pasotti via QGIS-Developer a écrit :
> Hi,
> QGIS is using the GDAL/OGR library to read the shapefiles.
which uses shapelib
> On Mon, Mar 27, 2023 at 9:51 AM 余 绍健 via QGIS-Developer
> <qgis-developer at lists.osgeo.org> wrote:
>> Dear All,
>>    Sorry to interrupt, I'm newer to QGIS, whe I use QIGS, I find that it is so quick for QGIS to parse shapefile even it is a very big file, I try to decode the file by my own with shapelib library, but the result is disappointed, I try to learn it by myself with QGIS source code but failed, so anyone can help point the entry of  decoding process?
>> Thanks.
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
http://www.spatialys.com
More information about the QGIS-Developer mailing list
