[QGIS-Developer] How does QGIS parses the shapefile so quickly
Werner Macho werner.macho at gmail.com
Mon Mar 27 08:18:24 PDT 2023
Hi!
Just to add some side information regarding Shapefiles:
(ignore it if understanding shapefiles ist a must in your case)
http://switchfromshapefile.org/
regards
Werner
On Mon, Mar 27, 2023 at 5:16 PM Even Rouault via QGIS-Developer <
qgis-developer at lists.osgeo.org> wrote:
> Le 27/03/2023 à 10:06, Alessandro Pasotti via QGIS-Developer a écrit :
> > Hi,
> > QGIS is using the GDAL/OGR library to read the shapefiles.
> which uses shapelib
> > On Mon, Mar 27, 2023 at 9:51 AM 余 绍健 via QGIS-Developer
> > <qgis-developer at lists.osgeo.org> wrote:
> >> Dear All,
> >>    Sorry to interrupt, I'm newer to QGIS, whe I use QIGS, I find that
> it is so quick for QGIS to parse shapefile even it is a very big file, I
> try to decode the file by my own with shapelib library, but the result is
> disappointed, I try to learn it by myself with QGIS source code but failed,
> so anyone can help point the entry of  decoding process?
> >> Thanks.
> >> _______________________________________________
> >> QGIS-Developer mailing list
> >> QGIS-Developer at lists.osgeo.org
> >> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> >> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> http://www.spatialys.com
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20230327/6978b32e/attachment.htm>
More information about the QGIS-Developer mailing list
