[QGIS-Developer] QtCreator QGIS debugging not showing values
Richard Duivenvoorde
rdmailings at duif.net
Fri Mar 31 02:48:06 PDT 2023
Thanks Nyall!
Works!
(after fiddling with patch...)
Richard
On 3/31/23 11:24, Nyall Dawson wrote:
> On Fri, 31 Mar 2023, 7:17 pm Richard Duivenvoorde via QGIS-Developer, <
> qgis-developer at lists.osgeo.org> wrote:
>> Hi Devs,
>> Trying to look into one of my own issues (wrong timestep count for mesh
>> layers #48942), I fail to see the values of variables in QtCreator see
>> screendump.
>> I tried to fiddle with Debuggers (gdb -> lldb), helpers, gdb properties
>> (Load system GDB pretty printers) etc etc. But I fail to see anything. Or
>> getting frequent qgis crashes from withing qtcreator...
>> Does this 'just work' with others? Or is everybody on Fedora now, or
>> should I learn to debug from terminal :-)?
>> Any clue for me?
> It's a bug in qt creator with newer python versions. See
> https://bugreports.qt.io/plugins/servlet/mobile#issue/QTCREATORBUG-28659
> There's a patch in that ticket which you can apply (doesn't require
> compiling) which resolves it.
> Nyall
>> My environment:
>> Debian testing
>> Qt 5.15.8
>> Qt Creator 9.0.2 (based on Qt 6.4.2)
>> GNU gdb (Debian 13.1-2) 13.1
>> Regards,
>> Richard Duivenvoorde_______________________________________________
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
