[QGIS-Developer] QtCreator QGIS debugging not showing values
Nyall Dawson nyall.dawson at gmail.com
Fri Mar 31 02:24:51 PDT 2023
On Fri, 31 Mar 2023, 7:17 pm Richard Duivenvoorde via QGIS-Developer, <
qgis-developer at lists.osgeo.org> wrote:
> Hi Devs,
> Trying to look into one of my own issues (wrong timestep count for mesh
> layers #48942), I fail to see the values of variables in QtCreator see
> screendump.
> I tried to fiddle with Debuggers (gdb -> lldb), helpers, gdb properties
> (Load system GDB pretty printers) etc etc. But I fail to see anything. Or
> getting frequent qgis crashes from withing qtcreator...
> Does this 'just work' with others? Or is everybody on Fedora now, or
> should I learn to debug from terminal :-)?
> Any clue for me?
It's a bug in qt creator with newer python versions. See
https://bugreports.qt.io/plugins/servlet/mobile#issue/QTCREATORBUG-28659
There's a patch in that ticket which you can apply (doesn't require
compiling) which resolves it.
Nyall
> My environment:
> Debian testing
> Qt 5.15.8
> Qt Creator 9.0.2 (based on Qt 6.4.2)
> GNU gdb (Debian 13.1-2) 13.1
> Regards,
> Richard Duivenvoorde_______________________________________________
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20230331/05c18fd4/attachment.htm>
More information about the QGIS-Developer mailing list
