[QGIS-Developer] Digitizing with Edit Menu
Jacky Volpes
jacky.volpes at oslandia.com
Tue May 2 00:26:23 PDT 2023
Hello,
Have you tried this following code? Using
iface.mapCanvas().mapTool().pointsZM() is good for me with any
digitizing tool, while drawing.
# Measurement object (adapt with crs/transform context/ellipsoid)
da = QgsDistanceArea()
da.setSourceCrs(QgsProject.instance().crs(),
QgsProject.instance().transformContext())
# If distance measurement must use ellipsoid
da.setEllipsoid(QgsProject.instance().ellipsoid())
# This is a demonstration function to adapt with your needs
def showArea(current_point):
if not isinstance(iface.mapCanvas().mapTool(),
QgsMapToolDigitizeFeature):
return
# Snapping
snapped_point =
iface.mapCanvas().snappingUtils().snapToMap(current_point).point()
if not snapped_point.isEmpty():
current_point = snapped_point
# Coordinates of currently drawn points in map coordinates
points = [QgsPointXY(point) for point in
iface.mapCanvas().mapTool().pointsZM()]
points.append(current_point)
# Get area
print(da.measurePolygon(points))
# Must be handled correctly in the final code, but here is for testing
iface.mapCanvas().xyCoordinates.connect(showArea)
Le 29/04/2023 à 01:45, Catania, Luke A ERDC-RDE-GRL-VA CIV via
QGIS-Developer a écrit :
> When you digitize a shape using the Edit menu in QGIS is the shape
> accessible? I am looking to get he area of the shape as it is drawn.
> I have added an event filter to my code to capture the coordinates and
> calculate it by creating a QgsGeometry, but my code is getting
> complicated as there are many shapes that a user can draw from this
> menu so if I can get access to this shape if it is temporary in
> memory, then I can just calculate the area on the shape and not have
> to capture all the positions of the mouse when clicked and moved.
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info:https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-developer
Jacky Volpes
Ingénieur SIG - Oslandia
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20230502/b12f758a/attachment-0001.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20230502/b12f758a/attachment-0001.png>
