[QGIS-Developer] Multiple python scripts in python console?
    Raymond Nijssen
    r.nijssen at terglobo.nl
    Thu May  4 07:02:18 PDT 2023
Hi Etienne,
Already tried what you are describing. Indeed it's inconvenient, and
sometimes the changes in the class code did not end up in the class
definition. For example, a newly defined function on the class was
unknown in script_1. Might be a bug, but I'm not even sure.
So the best way should be to tell QGIS to run another python script in
the console. Or go the plugin way.
Thanks and kind regards,
Raymond
On 04-05-2023 11:29, Etienne Trimaille wrote:
> If you are talking about the simple Python console panel, and loading
> Python files from there, then you can skip the " from .script_2 import
> TestClass".
> If you notice, when you launch the script_2.py, you have a generated
> line similar to :
> exec(Path('/tmp/tmp5g244g4w.py').read_text())
> So it's reading and executing all the content of file 2 in the console
> context already.
> So then, when file 1 will be executed, there will already be the class
> TestClass in the console context.
> But, then to manage multiple files, it's not convenient. You should
> think about the smallest plugin, for instance
> https://github.com/wonder-sk/qgis-minimal-plugin
> <https://github.com/wonder-sk/qgis-minimal-plugin> Otherwise, it's
> difficult to manage IMHO.
> Le jeu. 4 mai 2023 à 08:59, Raymond Nijssen via QGIS-Developer
> <qgis-developer at lists.osgeo.org <mailto:qgis-developer at lists.osgeo.org>>
> a écrit :
>     Hi developers,
>     While writing a python script in the QGIS python console editor I
>     needed
>     to write a new class and for convenience I put that in its own
>     python file.
>     Both files are in the same directory, but I cannot import my class in
>     the other script.
>     Here's an example:
>     # script_1.py
>     from .script_2 import TestClass
>     obj1 = TestClass('Ray')
>     print(obj1)
>     # script_2.py:
>     class TestClass():
>           def __init__(self, name):
>     self.name <http://self.name> = name
>           def __str__(self):
>               return f'TestClass[{self.name <http://self.name>}]'
>     It all works properly if I put my class definition in script_1 but as
>     the code is growing (and a customer of mine needs to understand this
>     too) it would really be nice to split the code over multiple files.
>     Is there a way? Or another approach?
>     Kind regards,
>     Raymond
>     _______________________________________________
>     QGIS-Developer mailing list
>     QGIS-Developer at lists.osgeo.org <mailto:QGIS-Developer at lists.osgeo.org>
>     List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>     <https://lists.osgeo.org/mailman/listinfo/qgis-developer>
>     Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
