[QGIS-Developer] Multiple python scripts in python console?
Etienne Trimaille
etienne.trimaille at gmail.com
Thu May 4 08:21:32 PDT 2023
> For example, a newly defined function on the class was
> unknown in script_1. Might be a bug, but I'm not even sure.
Well, for me it works without any issue.
But you need to re-execute the script_2.py in the Python console, it will
refresh the class definition in the Python console context then you can
execute script_1 again.
But indeed, you are reaching the limit of using the Python console like
this ...
Le jeu. 4 mai 2023 à 16:02, Raymond Nijssen <r.nijssen at terglobo.nl> a
écrit :
> Hi Etienne,
> Already tried what you are describing. Indeed it's inconvenient, and
> sometimes the changes in the class code did not end up in the class
> definition. For example, a newly defined function on the class was
> So the best way should be to tell QGIS to run another python script in
> the console. Or go the plugin way.
> Thanks and kind regards,
> Raymond
> On 04-05-2023 11:29, Etienne Trimaille wrote:
> > If you are talking about the simple Python console panel, and loading
> > Python files from there, then you can skip the " from .script_2 import
> > TestClass".
> > If you notice, when you launch the script_2.py, you have a generated
> > line similar to :
> > exec(Path('/tmp/tmp5g244g4w.py').read_text())
> > So it's reading and executing all the content of file 2 in the console
> > context already.
> > So then, when file 1 will be executed, there will already be the class
> > TestClass in the console context.
> > But, then to manage multiple files, it's not convenient. You should
> > think about the smallest plugin, for instance
> > https://github.com/wonder-sk/qgis-minimal-plugin
> > <https://github.com/wonder-sk/qgis-minimal-plugin> Otherwise, it's
> > difficult to manage IMHO.
> > Le jeu. 4 mai 2023 à 08:59, Raymond Nijssen via QGIS-Developer
> > <qgis-developer at lists.osgeo.org <mailto:qgis-developer at lists.osgeo.org>>
> > a écrit :
> > Hi developers,
> > While writing a python script in the QGIS python console editor I
> > needed
> > to write a new class and for convenience I put that in its own
> > python file.
> > Both files are in the same directory, but I cannot import my class in
> > the other script.
> > Here's an example:
> > # script_1.py
> > from .script_2 import TestClass
> > obj1 = TestClass('Ray')
> > print(obj1)
> > # script_2.py:
> > class TestClass():
> > def __init__(self, name):
> > self.name <http://self.name> = name
> > def __str__(self):
> > return f'TestClass[{self.name <http://self.name>}]'
> > It all works properly if I put my class definition in script_1 but as
> > the code is growing (and a customer of mine needs to understand this
> > too) it would really be nice to split the code over multiple files.
> > Is there a way? Or another approach?
> > Kind regards,
> > Raymond
> > QGIS-Developer mailing list
> > QGIS-Developer at lists.osgeo.org <mailto:
> QGIS-Developer at lists.osgeo.org>
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> > <https://lists.osgeo.org/mailman/listinfo/qgis-developer>
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20230504/7238518b/attachment.htm>
