[QGIS-Developer] No module named 'qgslayoutchecker' using "qgis/qgis:latest"
Matthias Kuhn
matthias at opengis.ch
Tue May 9 04:52:17 PDT 2023
Hi Harrissou,
I have a branch ready but github errors with 500 at the moment. As soon as
they got their services under control again, the PR will be opened
Matthias
On Tue, May 9, 2023 at 12:07 PM DelazJ via QGIS-Developer <
qgis-developer at lists.osgeo.org> wrote:
> Hi devs,
> Can someone please give it a look. Having every single commit report a
> failure for no (valid) reason is quite noisy and annoying. (issue report at
> https://github.com/qgis/QGIS/issues/53051)
> Thanks,
> Harrissou
> Le mar. 2 mai 2023 à 10:02, DelazJ <delazj at gmail.com> a écrit :
>> Hi Paolo,
>> Yes, we do have the same problems with testing in QGIS-Documentation
>> repository, for everything related to master branch (
>> https://github.com/qgis/QGIS-Documentation/actions/workflows/doctest.yml?query=branch%3Amaster).
>> 3.28 is fine.
>> Regards,
>> Harrissou
>> Le mar. 2 mai 2023 à 08:44, Paolo Tormene via QGIS-Developer <
>> qgis-developer at lists.osgeo.org> a écrit :
>>> Dear QGIS people,
>>> I am running continuous integration tests for a plugin using the
>>> 'qgis/qgis:latest' docker and, since 4 days ago, I am getting the following
>>> error:
>>> from qgis.testing import start_app
>>> usr/lib/python3/dist-packages/qgis/utils.py:888: in _import
>>> mod = _builtin_import(name, globals, locals, fromlist, level)
>>> usr/lib/python3/dist-packages/qgis/testing/__init__.py:56: in <module>
>>> from qgslayoutchecker import QgsLayoutChecker
>>> E ModuleNotFoundError: No module named 'qgslayoutchecker'
>>> Please note that the same tests run without issues using the
>>> 'qgis/qgis:release-3_22' docker instead.
>>> Has anyone experienced the same problem?
>>> Thank you and best regards,
>>> Paolo
>>> *PAOLO TORMENE* senior software developer +39 0382 5169882
>>> *GLOBAL EARTHQUAKE MODEL * working together to assess risk
>>> *GEM -* globalquakemodel.org <http://www.globalquakemodel.org> *T -*
>>> @GEMwrld <http://twitter.com/GEMwrld> *F -* GEMwrld
>>> <http://www.facebook.com/GEMwrld>
>>> QGIS-Developer mailing list
>>> QGIS-Developer at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20230509/4a6191ec/attachment.htm>
