[QGIS-Developer] No module named 'qgslayoutchecker' using "qgis/qgis:latest"
Matthias Kuhn matthias at opengis.ch
Tue May 9 05:43:31 PDT 2023
And it's open https://github.com/qgis/QGIS/pull/53053
Thanks Paolo, thanks Harrissou
On Tue, May 9, 2023 at 1:52 PM Matthias Kuhn <matthias at opengis.ch> wrote:
> Hi Harrissou,
> I have a branch ready but github errors with 500 at the moment. As soon as
> they got their services under control again, the PR will be opened
> Matthias
> On Tue, May 9, 2023 at 12:07 PM DelazJ via QGIS-Developer <
> qgis-developer at lists.osgeo.org> wrote:
>> Hi devs,
>> Can someone please give it a look. Having every single commit report a
>> failure for no (valid) reason is quite noisy and annoying. (issue report at
>> https://github.com/qgis/QGIS/issues/53051)
>> Thanks,
>> Harrissou
>> Le mar. 2 mai 2023 à 10:02, DelazJ <delazj at gmail.com> a écrit :
>>> Hi Paolo,
>>> Yes, we do have the same problems with testing in QGIS-Documentation
>>> repository, for everything related to master branch (
>>> https://github.com/qgis/QGIS-Documentation/actions/workflows/doctest.yml?query=branch%3Amaster).
>>> 3.28 is fine.
>>> Regards,
>>> Harrissou
>>> Le mar. 2 mai 2023 à 08:44, Paolo Tormene via QGIS-Developer <
>>> qgis-developer at lists.osgeo.org> a écrit :
>>>> Dear QGIS people,
>>>> I am running continuous integration tests for a plugin using the
>>>> 'qgis/qgis:latest' docker and, since 4 days ago, I am getting the following
>>>> error:
>>>> from qgis.testing import start_app
>>>> usr/lib/python3/dist-packages/qgis/utils.py:888: in _import
>>>>     mod = _builtin_import(name, globals, locals, fromlist, level)
>>>> usr/lib/python3/dist-packages/qgis/testing/__init__.py:56: in <module>
>>>>     from qgslayoutchecker import QgsLayoutChecker
>>>> E   ModuleNotFoundError: No module named 'qgslayoutchecker'
>>>> Please note that the same tests run without issues using the
>>>> 'qgis/qgis:release-3_22' docker instead.
>>>> Has anyone experienced the same problem?
>>>> Thank you and best regards,
>>>> Paolo
>>>> *PAOLO TORMENE* senior software developer +39 0382 5169882
>>>> *GLOBAL EARTHQUAKE MODEL * working together to assess risk
>>>> *GEM -* globalquakemodel.org <http://www.globalquakemodel.org> *T -*
>>>> @GEMwrld <http://twitter.com/GEMwrld> *F -* GEMwrld
>>>> <http://www.facebook.com/GEMwrld>
>>>> _______________________________________________
>>>> QGIS-Developer mailing list
>>>> QGIS-Developer at lists.osgeo.org
>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20230509/d1986568/attachment-0001.htm>
More information about the QGIS-Developer mailing list
