[QGIS-Developer] How to speed up rendering
    afernandez
    afernandez at odyhpc.com
    Mon May 29 19:35:53 PDT 2023
Hello Martin,
I'm trying to understand what you're saying but my background is in numerical methods where tasks are split into threads for acceleration purposes. If a single layer is rendered by a single core (as you write and I was observing), how would a 1,000 x 1,000 (or a 5,000 x 5,000) layer be handled? Wouldn't it take too long? (However, you want to define 'too long').
As far as more details about the process, the tensor 'var' (n x m x index where I have tried different combinations but let's say n x m is 100 x 200) of floating point numbers is manipulated according to the following pseudo-code:
# Initial manipulations
dims = var.dimensions
shape = var.shape
driver_name = 'GTIFF'
driver = gdal.GetDriverByName(driver_name)
np_dtype = var.dtype
type_code = gdal_array.NumericTypeCodeToGDALTypeCode(np_dtype)
gdal_ds = driver.Create(_my_path_, cols, rows, 1, gdal.GDT_UInt16)
gdal_ds.SetProjection(_my_projection_)
gdal_ds.SetGeoTransform(_my_transformation_)
# Creation of the bands and scaled matrix
band = gdal_ds.GetRasterBand(1)
data = var[_chosen_index_]
data = ma.getdata(data)
data_scaled = np.interp(data, (data.min(), data.max()), (0, 255))
data_scaled2 = data_scaled.astype(int) # This is to rescale into integers so that it can color the layer
# *** Lines to set up the color palette ***
# Write the array to band once everything has been rescaled
band.WriteArray(data_scaled2)
gdal_ds.FlushCache()
This procedure seems to work well and takes a reasonable amount of time. Then, the time is consumed when doing the rendering itself. I'm not entirely sure what you mean by 'sub-optimal raster format' or 'thre are overviews missing' so I cannot address them specifically.
Thanks,
Arturo
Martin Dobias wrote:
Hi
On Fri, May 26, 2023 at 11:30 PM afernandez via QGIS-Developer <qgis-developer at lists.osgeo.org <mailto:qgis-developer at lists.osgeo.org> > wrote:
Hello,
One of my project would greatly benefit from a much faster rendering. After some testing, the bulk (>99%) of the time is spent at rendering the layer with QgsRasterLayer(...,...). What I have also noticed is that rendering time does not change with the number of cores, which suggests that the renderer might be using a single thread. I checked the API documentation but couldn't find anything about multithreading or some other procedure to accelerate rendering. I was wondering if anyone has any suggestion or has faced a similar difficulty.
Multi-threaded rendering is done at the granularity of whole map layers, so a single layer is rendered by a single CPU core. Therefore if you have just one layer that is slow to render, the multi-threading is not going to help. It is best to do some testing how you can improve the layer's rendering - for example, it could be that you are using some sub-optimal raster format, or there are overviews missing, or something else... one would need more details.
Regards
Martin
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20230530/f1d5c678/attachment.htm>
