[QGIS-Developer] How to speed up rendering
Johannes Kröger (WhereGroup) johannes.kroeger at wheregroup.com
Tue May 30 01:00:42 PDT 2023
Hi Arturo,
make sure you create overviews on your big rasters or QGIS will re-read
the whole file all the time to render an appropriate representation in
the map.
Cheers, Hannes
Am 30.05.23 um 04:35 schrieb afernandez via QGIS-Developer:
> Hello Martin,
> I'm trying to understand what you're saying but my background is in
> numerical methods where tasks are split into threads for acceleration
> purposes. If a single layer is rendered by a single core (as you write
> and I was observing), how would a 1,000 x 1,000 (or a 5,000 x 5,000)
> layer be handled? Wouldn't it take too long? (However, you want to
> define 'too long').
> As far as more details about the process, the tensor 'var' (n x m x
> index where I have tried different combinations but let's say n x m is
> 100 x 200) of floating point numbers is manipulated according to the
> following pseudo-code:
> # Initial manipulations
>             dims = var.dimensions
>             shape = var.shape
>             driver_name = 'GTIFF'
>             driver = gdal.GetDriverByName(driver_name)
>             np_dtype = var.dtype
>             type_code = gdal_array.NumericTypeCodeToGDALTypeCode(np_dtype)
>             gdal_ds = driver.Create(_my_path_, cols, rows, 1,
> gdal.GDT_UInt16)
> gdal_ds.SetProjection(_my_projection_)
> gdal_ds.SetGeoTransform(_my_transformation_)
> # Creation of the bands and scaled matrix
>             band = gdal_ds.GetRasterBand(1)
>             data = var[_chosen_index_]
>             data = ma.getdata(data)
>             data_scaled =  np.interp(data, (data.min(), data.max()),
> (0, 255))
>             data_scaled2 = data_scaled.astype(int) # This is to
> rescale into integers so that it can color the layer
> # *** Lines to set up the color palette ***
> # Write the array to band once everything has been rescaled
>             band.WriteArray(data_scaled2)
>             gdal_ds.FlushCache()
> This procedure seems to work well and takes a reasonable amount of
> time. Then, the time is consumed when doing the rendering itself. I'm
> not entirely sure what you mean by 'sub-optimal raster format' or
> 'thre are overviews missing' so I cannot address them specifically.
> Thanks,
> Arturo
> Martin Dobias wrote:
>> Hi
>> On Fri, May 26, 2023 at 11:30 PM afernandez via QGIS-Developer
>> <qgis-developer at lists.osgeo.org> wrote:
>>     Hello,
>>     One of my project would greatly benefit from a much faster
>>     rendering. After some testing, the bulk (>99%) of the time is
>>     spent at rendering the layer with QgsRasterLayer(...,...). What I
>>     have also noticed is that rendering time does not change with the
>>     number of cores, which suggests that the renderer might be using
>>     a single thread. I checked the API documentation but couldn't
>>     find anything about multithreading or some other procedure to
>>     accelerate rendering. I was wondering if anyone has any
>>     suggestion or has faced a similar difficulty.
>> Multi-threaded rendering is done at the granularity of whole map
>> layers, so a single layer is rendered by a single CPU core. Therefore
>> if you have just one layer that is slow to render, the
>> multi-threading is not going to help. It is best to do some testing
>> how you can improve the layer's rendering - for example, it could be
>> that you are using some sub-optimal raster format, or there are
>> overviews missing, or something else... one would need more details.
>> Regards
>> Martin
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info:https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-developer
Johannes Kröger / GIS-Entwickler/-Berater
Aufwind durch Wissen!
Web-Seminare und Online-Schulungen
bei derwww.foss-academy.com
WhereGroup GmbH
c/o KK03 GmbH
Lange Reihe 29
20099 Hamburg
Germany
Tel: +49 (0)228 / 90 90 38 - 36
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Geschäftsführer:
Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRB 9885
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20230530/428520ac/attachment-0001.htm>
More information about the QGIS-Developer mailing list
