[QGIS-Developer] Next QGIS LTR and its compatibility with older versions
Nyall Dawson nyall.dawson at gmail.com
Mon Oct 2 17:39:12 PDT 2023
On Tue, 3 Oct 2023 at 00:16, Andreas Neumann via QGIS-Developer
<qgis-developer at lists.osgeo.org> wrote:
> About your second question: don't nail me down on this but all 3.x versions should open with the newest 3.x version - it should be even possible to open version 2 files with the latest 3.x version.
It's definite! If you run into issues opening a project made in an
older 3.x version in a newer QGIS version, then it's a bug which must
be fixed!
Nyall
> Greetings,
> Andreas
> On 2023-10-02 15:57, Raffael Meier via QGIS-Developer wrote:
> Hello
> I would like to know if this is correct, that the next long term release of a stable QGIS version (3.34.0) will be at the end of October 2023?
> If this is correct I would like to know if I worked with an older version and I want to continue working on this project with the upcoming LTR what ist he oldest QGIS version files that
> I can still use with the new LTR (3.34.0).
> Best regards,
> Raffael
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
More information about the QGIS-Developer mailing list
