[QGIS-Developer] Loading DXF in QGIS?
Catania, Luke A ERDC-RDE-GRL-VA CIV
Luke.A.Catania at erdc.dren.mil
Mon Oct 2 15:47:58 PDT 2023
I have a DXF in both AC1027 and AC1032 format. Original file was a DWG. I converted to DXF using ODA File Converter. I am trying to load in QGIS and dragging and dropping or using the Data Source Manager results in a layer with the name "entities appended to it and nothing shows up. When looking at the properties there is not much there. The layer type is a dataset. I am trying to display all the lines of the dxf.
[cid:image001.png at 01D9F560.C7213C90]
[cid:image004.png at 01D9F560.F598D600]
[cid:image003.png at 01D9F560.C7213C90]
Now I can use the Project/Import/Export/Import Layers from DWG/DXF to import, but I am looking to do this programmatically in python and I am using ezdxf to assist.
Ideas?
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20231002/50adfb68/attachment-0001.htm>
Type: image/png
Desc: image001.png
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20231002/50adfb68/attachment-0003.png>
Type: image/png
Desc: image003.png
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20231002/50adfb68/attachment-0004.png>
Type: image/png
Desc: image004.png
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20231002/50adfb68/attachment-0005.png>
