[QGIS-Developer] Loading DXF in QGIS?
Stefan Giese (WhereGroup)
stefan.giese at wheregroup.com
Mon Oct 2 23:59:19 PDT 2023
with ezdxf you can do the job. The following snippet shows how it works:
/#Reading the dxf and get the modelspace
dwg = ezdxf.readfile(filepath)
msp = dwg.modelspace()
#loop through all Polylines of the DXF
polylines = msp.query('POLYLINE')
for polyline in polylines:/
/ # for example converts a dxf Polyline to a QgsGeometry (Polygon)
points = []
for i, location in enumerate(polyline.points()):
points.append(QgsPointXY(location[0],location[1]))
polygon = QgsGeometry.fromPolygonXY([points])/
hope this will be a starting point for you...
Mit freundlichen Grüßen
Stefan Giese
Projektleiter/Consultant
Aufwind durch Wissen!
Web-Seminare und Online-Schulungen
bei derwww.foss-academy.com
WhereGroup GmbH
Schwimmbadstr. 2
79100 Freiburg
Germany
Tel.: +49 (0)761 / 519 102 - 61
Fax: +49 (0)761 / 519 102 - 11
www.wheregroup.com
Geschäftsführer:
Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRB 9885
Am 03.10.2023 um 00:47 schrieb Catania, Luke A ERDC-RDE-GRL-VA CIV via
QGIS-Developer:
> I have a DXF in both AC1027 and AC1032 format. Original file was a
> DWG. I converted to DXF using ODA File Converter. I am trying to
> load in QGIS and dragging and dropping or using the Data Source
> Manager results in a layer with the name “entities appended to it and
> nothing shows up. When looking at the properties there is not much
> there. The layer type is a dataset. I am trying to display all the
> lines of the dxf.
> Now I can use the Project/Import/Export/Import Layers from DWG/DXF to
> import, but I am looking to do this programmatically in python and I
> am using ezdxf to assist.
> Ideas?
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info:https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20231003/bf4ee5e4/attachment-0001.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20231003/bf4ee5e4/attachment-0003.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20231003/bf4ee5e4/attachment-0004.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20231003/bf4ee5e4/attachment-0005.png>
