[QGIS-Developer] Loading DXF in QGIS?
Catania, Luke A ERDC-RDE-GRL-VA CIV Luke.A.Catania at erdc.dren.mil
Tue Oct 3 13:29:52 PDT 2023
Assume though the shown variable dwg I am really reading a dxf since readfile did not work on my DWG.  I converted it to DXF using ODA file converter.
I tried it with my dxf but it never went through the loop, so it did not find POLYLINES.  When I bring the dxf  in using QGIS’s Project/Import/Export/Import Layers from DWG/DXF, I see it shows several named layers, but I tried searching on the ones that showed up in the QGIS layer panel  of these and nothing was found.
[cid:image004.png at 01D9F616.D36F2410]
[cid:image005.png at 01D9F616.D36F2410]
From: QGIS-Developer <qgis-developer-bounces at lists.osgeo.org> On Behalf Of Stefan Giese (WhereGroup) via QGIS-Developer
Sent: Tuesday, October 3, 2023 2:59 AM
To: qgis-developer at lists.osgeo.org
Subject: Re: [QGIS-Developer] Loading DXF in QGIS?
with ezdxf you can do the job. The following snippet shows how it works:
#Reading the dxf and get the modelspace
    dwg = ezdxf.readfile(filepath)
    msp = dwg.modelspace()
    #loop through all Polylines of the DXF
    polylines = msp.query('POLYLINE')
    for polyline in polylines:
       # for example converts a dxf Polyline to a QgsGeometry (Polygon)
       points = []
       for i, location in enumerate(polyline.points()):
           points.append(QgsPointXY(location[0],location[1]))
      polygon = QgsGeometry.fromPolygonXY([points])
hope this will be a starting point for you...
Mit freundlichen Grüßen
Stefan Giese
Projektleiter/Consultant
Aufwind durch Wissen!
Web-Seminare und Online-Schulungen
bei der Blockedwww.foss-academy.comBlocked<Blockedhttp://www.foss-academy.comBlocked>
WhereGroup GmbH
Schwimmbadstr. 2
79100 Freiburg
Germany
Tel.: +49 (0)761 / 519 102 - 61
Fax: +49 (0)761 / 519 102 - 11
stefan.giese at wheregroup.com<mailto:stefan.giese at wheregroup.com>
Blockedwww.wheregroup.comBlocked<Blockedhttp://www.wheregroup.comBlocked>
Geschäftsführer:
Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRB 9885
Am 03.10.2023 um 00:47 schrieb Catania, Luke A ERDC-RDE-GRL-VA CIV via QGIS-Developer:
I have a DXF in both AC1027 and AC1032 format.  Original file was a DWG.  I converted to DXF using ODA File Converter.  I am trying to load in QGIS and dragging and dropping or using the Data Source Manager results in a layer with the name “entities appended to it and nothing shows up.  When looking at the properties there is not much there. The layer type is a dataset.  I am trying to display all the lines of the dxf.
[cid:image001.png at 01D9F614.283AA0D0]
[cid:image002.png at 01D9F614.283AA0D0]
[cid:image003.png at 01D9F614.283AA0D0]
Now I can use the Project/Import/Export/Import Layers from DWG/DXF to import, but I am looking to do this programmatically in python and I am using ezdxf to assist.
Ideas?
QGIS-Developer mailing list
QGIS-Developer at lists.osgeo.org<mailto:QGIS-Developer at lists.osgeo.org>
List info: Blockedhttps://lists.osgeo.org/mailman/listinfo/qgis-developerBlocked
Unsubscribe: Blockedhttps://lists.osgeo.org/mailman/listinfo/qgis-developerBlocked
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20231003/52a6c54f/attachment-0001.htm>
Type: image/png
Desc: image001.png
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20231003/52a6c54f/attachment-0005.png>
Type: image/png
Desc: image002.png
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20231003/52a6c54f/attachment-0006.png>
Type: image/png
Desc: image003.png
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20231003/52a6c54f/attachment-0007.png>
Type: image/png
Desc: image004.png
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20231003/52a6c54f/attachment-0008.png>
Type: image/png
Desc: image005.png
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20231003/52a6c54f/attachment-0009.png>
More information about the QGIS-Developer mailing list
