[QGIS-Developer] Reading current measurement with python
Simon Gröchenig groechenig at zt-gis.at
Mon Oct 9 00:45:34 PDT 2023
> As I don't have the context explaining why you need this
I try to "save" measurements as annotation or linestring/area layer in order to see measurements in layouts.
Currently, I copy (linear) measurements and use the coordinates from QGuiApplication.clipboard() to draw a temporary linestring. I would like to skip copying the measurements. Also, I would like to "save" area measurements where copy is not supported by the measurement gui.
Any ideas?
Simon
-----Ursprüngliche Nachricht-----
Von: Jacky Volpes <jacky.volpes at oslandia.com>
Gesendet: Freitag, 6. Oktober 2023 15:00
An: qgis-developer at lists.osgeo.org
Cc: Simon Gröchenig <groechenig at zt-gis.at>
Betreff: Re: [QGIS-Developer] Reading current measurement with python
Hi Simon,
Ok, I understand your question now.
Unfortunately, the measurement tool is not accessible with the python API.
As I don't have the context explaining why you need this, I can propose you to find another way for your process, or, if you really need to get the measurement value, here is a code snippet that finds the text within the measurement dialog (I don't recommend you to use this in a production environment though, or you might have unexpected behaviors if something changes in the dialog implementation).
measurementDialogs = [d for d in
iface.mainWindow().findChildren(QDialog, "QgsMeasureBase") if d.isVisible()] if len(measurementDialogs) == 1:
     measurementDialog = measurementDialogs[0]
     totalTextLineEdit = measurementDialog.findChild(QLineEdit, "editTotal")
     if totalTextLineEdit is not None:
         print(totalTextLineEdit.text())
Best regards,
Jacky Volpes
Ingénieur SIG - Oslandia
Le 04/10/2023 à 10:15, Simon Gröchenig a écrit :
> Hi Jacky,
> thanks for your help and for pointing me to this code snippet.
> However, I see that the measurement tools are instances of QgsMapTool with an QAction (and not QgsMapToolDigitizeFeature) and therefore mapTool().pointsZM() is not available.
> Now I wonder if I can utilize the QgsRubberBand
> Best regards
> Simon
> Message: 2
> Date: Mon, 2 Oct 2023 08:56:58 +0200
> From: Jacky Volpes <jacky.volpes at oslandia.com>
> To: qgis-developer at lists.osgeo.org
> Subject: Re: [QGIS-Developer] Reading current measurement with python
> Message-ID: <352a9e94-9010-4f39-8738-89323a87a15a at oslandia.com>
> Content-Type: text/plain; charset="utf-8"; Format="flowed"
> Hi,
> You can have a look at this snippet:
> https://lists.osgeo.org/pipermail/qgis-developer/2023-May/065789.html
> Regards,
> Jacky Volpes
> Ing?nieur SIG - Oslandia
> Le 02/10/2023 ? 07:05, Simon Gr?chenig via QGIS-Developer a ?crit?:
>> Hi list,
>> is it possible to get the current line/area measurement with Python?
>> Simon
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info:https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-developer
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20231002/ce6f1c41/attachment-0001.htm>
More information about the QGIS-Developer mailing list
