[QGIS-Developer] QGIS 3D and Graphics Card Requirements
C Hamilton adenaculture at gmail.com
Tue Oct 10 10:04:01 PDT 2023
I just noticed this thread. For what it's worth, many of my users are
running QGIS on virtual machines. I don't advertise the QGIS 3D
capabilities because it performs badly in the VM environment or not at all.
Even on my personal laptop which is a fast machine with a decent video
card, but does not have a high end graphics card, I find the 3D
performance to be slow enough that I don't use it. I have played around a
little bit with Blender 3D and it wasn't slow.
Calvin
On Tue, Oct 10, 2023 at 6:57 AM Johannes Kröger (WhereGroup) via
QGIS-Developer <qgis-developer at lists.osgeo.org> wrote:
> Hi all,
> the two ridiculously expensive and high-end graphics cards mentioned by
> Luke sound like complete overkill. Surely reading and preparing the geodata
> for 3D display (from data providers, via storage, on the CPU?) would be the
> bigger performance/usability issue of the 3D views, right? I am sure that
> for reasonable reasons QGIS would choke waaaay earlier than what those
> cards would be capable of. The potential benefit of those cards for QGIS 3D
> definitely is not worth paying *1200-2500€* extra.
> Martin/Jean, is there any change that you could provide a more detailed
> specification of the hardware and software requirements for QGIS 3D? It
> comes up again and again and I've just been searching again without
> success. I step up to add it to the QGIS documentation in early November.
> Esri provides for example infos on the required OpenGL version and
> extensions on
> https://pro.arcgis.com/en/pro-app/latest/get-started/arcgis-pro-system-requirements.htm
> E.g.: What is the minimum amount of GPU RAM necessary? How does it scale
> with more complex 3D scenes and what happens if there is not enough RAM?
> Does it get slow (maybe with a message) or does it crash? Which renderer
> does it use on which platforms (I guess always OpenGL?). Which OpenGL
> version is needed? Which extensions are needed? Could missing extensions
> get logged prominently to the user to avoid the "my 3D canvas is
> white/blank" issue (I guess that is the reason) that often comes up? Which
> features depend on which extensions and what happens if they are not
> available?
> All the best, Hannes
> Am 21.09.23 um 09:56 schrieb Martin Dobias via QGIS-Developer:
> Hey Luke
> Low end graphics cards should work fine as well. If your coworker could
> not run 3D on his laptop, it could have been some other problem - it would
> be good to have more details (hardware spec, operating system, in what way
> things did not work) so that we can fix such issues. For example, my laptop
> has 2GB of GPU memory and things work just fine. So both of the suggested
> graphics cards should give you much more power for QGIS 3D than you would
> normally need.
> Cheers
> Martin
> On Wed, Sep 20, 2023 at 11:20 PM Catania, Luke A ERDC-RDE-GRL-VA CIV via
>> Anyone out there working with QGIS 3D?
>> I am looking to get a new Dell laptop with i9 processor and 64GB memory
>> and wondering what the minimum requirements for working with QGIS 3D is.  I
>> had a coworker who could not run 3D on his laptop assume due to his lower
>> end graphics card.  I don’t offhand know what the spec’s on his machine are.
>> I am looking at a Dell 7780 or 7680 with either *NVIDIA RTX 5000 Ada
>> 16GB GDDR6 video card *or the* RTX 4000 Ada* *12GB GDDR6 video card.*
>> Wondering if the higher end card buys me much better performance and is
>> worth the hit on battery life.
>> Luke
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20231010/5e744f76/attachment-0001.htm>
More information about the QGIS-Developer mailing list
