[QGIS-Developer] pygdaltools library documentation sparce
Catania, Luke A ERDC-RDE-GRL-VA CIV
Luke.A.Catania at erdc.dren.mil
Tue Oct 10 22:20:33 PDT 2023
OK. I am doing a bunch of GDAL commands in my QGIS plugin so opted for this forum.
-----Original Message-----
Sent: Wednesday, October 11, 2023 1:19 AM
To: Catania, Luke A ERDC-RDE-GRL-VA CIV <Luke.A.Catania at erdc.dren.mil>
Cc: qgis-developer at lists.osgeo.org
Subject: Re: [QGIS-Developer] pygdaltools library documentation sparce
On Wed, 11 Oct 2023 at 15:15, Catania, Luke A ERDC-RDE-GRL-VA CIV via QGIS-Developer <qgis-developer at lists.osgeo.org> wrote:
> Anyone use pygdaltools?
You're better off asking this on the GDAL-Dev list, rather than QGIS-Dev.
Nyall
> import gdaltools
> gdal_tools = gdaltools.ogr2ogr()
> gdal_tools.BASEPATH = r"C:\Program Files\QGIS 3.16.16\bin"
> gdal_tools.set_encoding("UTF-8")
> gdal_tools.set_input(self.dxf_out_path)
> gdal_tools.set_output(self.gpkg_out)
> gdal_tools.execute()
> And I get the ERROR:root:b"Warning 1: Layer creation options ignored since an existing layer is\r\n being appended to.\r\nWarning 6: Normalized/laundered field name: 'EntityHandle' to 'EntityHa_2'\r\nERROR 1: Attempt to write non-linestring (GEOMETRYCOLLECTION) geometry to ARC type shapefile.\r\nERROR 1: Unable to write feature 0 from layer entities.\r\nERROR 1: Terminating translation prematurely after failed\r\ntranslation of layer entities (use -skipfailures to skip errors)\r\n"
> Traceback (most recent call last):
> File
> "c:\Users\RDTECLAC\AppData\Roaming\QGIS\QGIS3\profiles\default\python\
> plugins\site_selection\tools\master_planning\load_mp_designs.py", line
> 227, in <module>
> main()
> File
> 196, in main
> mp_designs.gdal_convert()
> File
> 185, in gdal_convert
> File
> "C:\Users\RDTECLAC\AppData\Roaming\Python\Python39\site-packages\gdalt
> ools\ogr2ogrcmd.py", line 330, in execute
> return self._do_execute(args)
> File
> ools\basetypes.py", line 108, in _do_execute
> raise GdalToolsError(rc, err)
> gdaltools.basetypes.GdalToolsError: (1, b"Warning 1: Layer creation options ignored since an existing layer is\r\n being appended to.\r\nWarning 6: Normalized/laundered field name: 'EntityHandle' to 'EntityHa_2'\r\nERROR 1: Attempt to write non-linestring (GEOMETRYCOLLECTION) geometry to ARC type shapefile.\r\nERROR 1: Unable to write feature 0 from layer entities.\r\nERROR 1: Terminating translation prematurely after failed\r\ntranslation of layer entities (use -skipfailures to skip errors)\r\n")error:
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info:
> Blockedhttps://lists.osgeo.org/mailman/listinfo/qgis-developerBlocked
> Unsubscribe:
