[QGIS-Developer] QGIS repository management
Nyall Dawson
nyall.dawson at gmail.com
Sun Oct 15 12:58:30 PDT 2023
Hi Sandro,
Thanks for raising this discussion. I'll add my knowledge inline below.
But please keep in mind that all this stuff has just been set over time in
a reactionary/evolutionary process to keep things running smoothly, rather
than something which was designed and formalised by a committee in advance.
There's always room for improvement and revision to match current needs! 👍
On Sat, 14 Oct 2023 at 05:43, Sandro Santilli via QGIS-Developer <
qgis-developer at lists.osgeo.org> wrote:
> It's not just me, I think, but I cannot tell for sure because the
configuration
> of the infrastructure currently in use (github) is not available for me
to see
> and the governance page on the official QGIS website does not contain this
> information [2]. This being blind of course adds up to my frustration.
This page **definetly** needs an update. There's information on that page
which is ~decades out of date (eg Larry Shaffer hasn't been involved in the
project for around 10 years, the OSX packaging team is incorrect, and the
whole "testing" team is non-existent, etc).
I'm happy to help out here with removing old content. My gut feeling is
that a more exhaustive rework is needed and repository / process related
information doesn't belong on this page, and the page should be left to the
"organisation" level governance information alone.
> From experience, I know that the reason why I cannot write to the QGIS
> repository is because "branch protection" is active (for the master branch
> at least) and a set of conditions are required to merge a PR, namely:
> - All CI tests need to pass.
> - Someone else (I don't know from which group of people) needs to
> approve the proposed change.
Correct. And I would argue that both of these requirements are a valid
**MINIMUM** protection choice for introducing code into a project which has
real world cost impacts for users exceeding millions and potentially
impacting the lives and safety of others.
> 1. CI is often broken for reasons that are independent from the proposed
> change.
Definitely a valid issue, and a real PITA. I'm probably restarting that
mingw workflow ~20x a day for everyone's(!) PRs to keep it limping along.
That said, I'd still rather limp this workflow along vs removing it,
because I do believe that it adds value to our tests and gives end users an
easy way to test PRs prior to merge. I feel the same about the noisy
clang-tidy check: it has a LOT of false positives, but around 1 in 10
failures in that workflow is a valid bug which has been flagged prior to
introducing the code. That's still a net win in my view.
> 2. An aberration of the "review" condition is that a change proposed by a
> contributor and approved by me can be merged but a change proposed by
> me and approved by the same contributor can not be merged, effectively
> giving me ("core QGIS committer") less power than the power of a random
> contributor.
Maybe -- but I would argue that you're looking at the "core contributor"
privilege incorrectly. It's no longer a "you are trusted to put whatever
code you want into the project" vs a "you are trusted to peer review and
approve code proposed for introduction into the project".
Ie **everyone** is on the same level wrt to submitting code for review, but
only the trusted group of core committers are permitted to approve this
code for introduction to QGIS.
> 1. Clearly document the roles and rules on the website
+1
> 2. Allow those with "write access" to self-approve PRs
-1. What's the real motivation here? Why the urgency to get unreviewed code
into QGIS? Again, I am strongly of the opinion that more exhaustive code
merging policies protects our users and their trust in QGIS.
> 3. Define rules by which "write access" privileges to the repository
> are revoked
+1
Nyall
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20231016/2fb95570/attachment.htm>
