[QGIS-Developer] Dropping "render" checkbox from status bar
Nick Bearman
nick at geospatialtrainingsolutions.co.uk
Mon Oct 16 06:40:17 PDT 2023
Hi Nyall / all,
You might be interested that the Ordnance Survey documentation for OS
Features API makes use of the "render" check box in the setup when
pulling data from their API. See
https://osdatahub.os.uk/docs/wfs/gettingStarted under QGIS and search
for "render".
Whether or not this is a good idea or is needed I don't know but I
thought you might be interested that it is used here.
For the record - I am not linked with Ordnance Survey and didn't write
the instructions, I just used them a couple of times!
Best wishes,
Nick.
On 16/10/2023 07:47, Régis Haubourg via QGIS-Developer wrote:
> Same here. I use this when playing with huge datasets.
> Cheers
> Régis
> Le dim. 15 oct. 2023, 23:39, Nicolas Cadieux via QGIS-Developer
> <qgis-developer at lists.osgeo.org> a écrit :
> Hi,
> Still useful on my side when rendering very heavy stuff and then
> decide to zoom to another part of the map…
> Nicolas Cadieux
> > Le 15 oct. 2023 à 15:30, Nyall Dawson via QGIS-Developer
> > Hi list,
> > Question: are there still any valid use cases for the "render"
> > checkbox in the status bar? It's been around forever, and DID have a
> > strong use case when map rendering used to block the QGIS interface.
> > But is there any reason to keep this around in modern QGIS versions?
> > Nyall
> > QGIS-Developer mailing list
> > QGIS-Developer at lists.osgeo.org
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> List info:https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-developer
Nick Bearman
+44 (0) 7717745715
Due to my own life/work balance, you may get emails from me outside of normal working hours. Please do not feel any pressure to respond outside of your own working pattern.
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20231016/a37a25c9/attachment.htm>
