[QGIS-Developer] loading projects in startup.py
Karsten Tebling
tebling at masuch.de
Mon Oct 23 01:51:00 PDT 2023
Hello,
I'm trying to load different projects depending on some parameters in
startup.py but I can't get it to work. If I try to load the projects
directly via QgsProject.instance().read(), nothing happens at all at
startup. If I try to change the "qgis/projOpenAtLaunch"-setting, the
change only affects the next start of QGIS, not the current start, which
is kind of confusing.
Any suggestions?
Cheers,
Karsten
