[QGIS-Developer] QGIS-Documentation fails to build
DelazJ
delazj at gmail.com
Tue Oct 24 04:28:04 PDT 2023
Hello devs,
It did not happen for a moment but ... QGIS documentation build is
failing today, due to a "No styles available in DB" [0] issue while
running doctest. Maybe it has to do with PR 54978 [1]? I don't have idea
nor time to look for a fix, and would welcome your help.
Thanks.
[0]
https://github.com/qgis/QGIS-Documentation/actions/runs/6623049639/job/17991561077#step:8:991
[1] https://github.com/qgis/QGIS/pull/54978
Greetings,
Harrissou
Le 19/05/2022 à 16:10, Andreas Neumann a écrit :
> Hi Alessandro,
> Fine with me - if you spend some dev hours on fixing this.
> Andreas
> On Thu, 19 May 2022 at 12:09, Alessandro Pasotti via QGIS-Developer
> <qgis-developer at lists.osgeo.org> wrote:
> Hi,
> I cannot make promises, but if I'm allowed to spend the paid bugfixing
> hours to fix this I think I could have a look.
> Cheers
> On Thu, May 19, 2022 at 12:06 PM DelazJ via QGIS-Developer
> > Hi,
> > well...
> > For your information, I disabled the doctest github action, to
> stop getting annoyed by (unrelated) failure messages for each
> interaction with the repository.
> > That also means no more checks for the PyQGIS Cookbook changes
> (which includes this recent pull request), until we get a fix.
> > Greetings,
> > Harrissou
> > Le lun. 9 mai 2022 à 16:35, DelazJ <delazj at gmail.com> a écrit :
> >> Hi,
> >> Thanks again Richard for testing.
> >> Any chance someone else gives it a look, please? Thanks.
> >> Regards,
> >> Harrissou
> >> Le mar. 3 mai 2022 à 20:44, Richard Duivenvoorde via
> QGIS-Developer <qgis-developer at lists.osgeo.org> a écrit :
> >>> On 5/3/22 11:35, DelazJ via QGIS-Developer wrote:
> >>> > Hi devs,
> >>> > The "doctest" workflow in QGIS-Documentation repository is
> again broken. We are getting a segmentation fault [0]. This might
> have begun at least 5 days ago, only on master branch. The 3.22
> doctest passes.
> >>> > If someone can give it a look, it will be much appreciated.
> Thanks.
> >>> Hi Harrissou,
> >>> I tried looking into it...
> >>> A normal local build is fine... (so in a VENV with the
> REQUIREMENTS.txt of QGIS-Website, calling "make html")
> >>> But that does not build the doc tests (the python code in the
> cookbook is tested in that)
> >>> Then I tried on my local machine, what I see in the CI log:
> >>> make -f docker.mk <http://docker.mk> doctest
> >>> and that fails with exact the same messages, except it looks
> like it crashes on random parts of the cookbook tests
> >>> @devs can anybody of you make something from the stacktrace?
> >>> SIP related?
> >>> Missing dependency?
> >>> Any hints appreciated
> >>> Regards,
> >>> _______________________________________________
> >>> QGIS-Developer mailing list
> >>> QGIS-Developer at lists.osgeo.org
> >>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> >>> Unsubscribe:
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Alessandro Pasotti
> QCooperative: www.qcooperative.net <http://www.qcooperative.net>
> ItOpen: www.itopen.it <http://www.itopen.it>
> Andreas Neumann
> QGIS.ORG <http://QGIS.ORG> board member (treasurer)
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20231024/5a64a6d0/attachment.htm>
