[QGIS-Developer] Plugin using Pythonnet fails to start during installation
Benjamin Jakimow
benjamin.jakimow at geo.hu-berlin.de
Wed Apr 10 05:13:20 PDT 2024
Dear Lars,
this looks like your plugin's __init__.py (that one that contains the
"def classFactory(iface)") want's to import the LIFA_ejdexplorer before
it's location is added to the PYTHONPATH
You may need something like:
sys.path.append('folder to LIFA_ejdexplorer')
before the classFactory(iface) is called.
Greetings,
Benjamin
On 09/04/2024 10:49, Lars I. Nielsen via QGIS-Developer wrote:
> Hi developers.
> We’ve developed a QGIS plugin, that utilizes Pythonnet to communicate
> with C# on Windows.
> Pythonnet is not part of the chosen distribution for Python in QGIS (as
> of 3.34), so we do a separate installation of this module into
> %APPDATA%/Python, which is used by all Python distributions on the PC.
> But even after Pythonnet has been installed correctly, we get an error
> when the QGIS plugin installer tries to start the plugin.
> However, the plugin has been installed correctly, and it starts just
> fine when one manually activates it in the plugin window list.
> Why can’t the plugin start when activated by the QGIS plugin installer ?
> Is it running in some kind of restricted environment, that excludes use
> of the APPDATA location ?
> Cheers.
> Ps!
> We are aware of different versions of Pythonnet in Python 3.7 vs 3.9. We
> install both.
> Med venlig hilsen
> *Lars I. Nielsen*
> GIS-kons., FME+Python Certified Professional
> GeoData
> Dir.
> +4563136849 <tel:+4563136849>
> Tlf.
> +4563136800 <tel:+4563136800>
> Mail
> +lin at lifa.dk <mailto:lin at lifa.dk>
> LIFA A/S · Tlf +4563136800 <tel:+4563136800>· lifa.dk
> <https://www.lifa.dk/>· CVR 20937289
> Odense · Fredericia · Glostrup · Hillerød · Kerteminde · Kolding ·
> Middelfart · Vejle · Vissenbjerg · Aarhus
> <https://www.linkedin.com/company/lifa-a-s/>
> Følg os på LinkedIn og læs de seneste nyheder fra LIFA A/S.
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Dr. Benjamin Jakimow
Earth Observation Lab | Geography Department | Humboldt-Universität zu
Berlin
e-mail: benjamin.jakimow at geo.hu-berlin.de
phone: +49 (0) 30 2093 6846
mobile: +49 (0) 157 5656 8477
fax: +49 (0) 30 2093 6848
mail: Unter den Linden 6 | 10099 Berlin | Germany
matrix: @jakimowb:hu-berlin.de
web: https://hu-berlin.de/eo-lab
