[QGIS-Developer] Modeler: Can a QgsProcessingOutputVariant be a QgsProcessingParameterGeometry for child algorithm?
René-Luc Dhont
rldhont at gmail.com
Mon Apr 15 10:33:26 PDT 2024
Hi devs,
I have found an issue and proposed fix
https://github.com/qgis/QGIS/pull/57150 that has been merged and backported.
It will be possible to chain algorithm on Point and Geometry.
René-Luc
Le 05/04/2024 à 18:52, René-Luc Dhont a écrit :
> Hi devs,
> I'm trying to build algorithms with geometry ouput.
> It seems that QgsProcessingOutputVariant has been build for it.
> But if I use my algorithms in a model with QGIS 3.34 :
> * I can't provide a name to QgsProcessingOutputVariant to become model
> algorithm ouput
> * I can't use QgsProcessingOutputVariant as a parameter for a child
> algorithm
> What is the QgsProcessingOutputVariant use case?
> Which QgsProcessingOutputVariant has been defined for?
> Thanks,
> René-Luc
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20240415/4b8d3284/attachment.htm>
