[QGIS-Developer] Modeler: What's missing to define string, number or other simple outputs
René-Luc Dhont
rldhont at gmail.com
Mon Apr 15 10:43:47 PDT 2024
Hi devs,
It seems it is not possible to define string, number, boolean or variant
output for modeler algorithm.
For example, if you add Delete duplicate geometries
`native:deleteduplicategeometries` algorithm in a model, you will not be
able to define the name for the outputs Count of retained records
RETAINED_COUNT and Count of discarded duplicate records DUPLICATE_COUNT.
So what's missing to be able to define the name for string, number,
boolean or variant output to ensure that these became model algorithm
output ?
Regards,
René-Luc
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20240415/53899a07/attachment.htm>
