[QGIS-Developer] question
Abdelghani Tamort
abdel.tmrt at gmail.com
Thu Apr 25 05:47:13 PDT 2024
Hi Saber,
>From the link you sent, I tried some code lines. For instance, I tried "
iface.mapCanvases3D()" but It doesn't seem to work, I'm getting the
following error: AttributeError: 'QgisInterface' object has no attribute
'mapCanvases3D'. I'm working on QGIS 3.34.5.
Kind regards,
Abdelghani
On Fri, 12 Apr 2024 at 15:49, Saber Razmjooei <
saber.razmjooei at lutraconsulting.co.uk> wrote:
> Hi,
> You can find more code snippet and examples here:
> https://www.lutraconsulting.co.uk/blog/2024/02/05/new-features-in-qgis-36/
> Kind regards
> Saber
> On Fri, 12 Apr 2024 at 11:58, Johannes Kröger (WhereGroup) via
> QGIS-Developer <qgis-developer at lists.osgeo.org> wrote:
>> Hi,
>> afaik the 3D Python API is not fully finalized yet. But you can already
>> control some aspects of it from Python, mostly the views themselves.
>> This was added recently, see https://github.com/qgis/QGIS/pull/55862
>> Have fun!
>> Hannes
>> On 12.04.24 11:30, Abdelghani Tamort via QGIS-Developer wrote:
>> > Hello,
>> > I want to post a message (which contains an inquiry) to the qgis
>> > developer list.
>> > The message is the following:
>> > Is there a solid documentation/tutorials on handling 3D on QGIS's
>> > python API ? Currently working on a QGIS plugin that exports data in
>> > 3D format and trying to make use of the 3D views in QGIS to visualize
>> > the outputs. I am aware of the Qgis2threejs plugin
>> > (https://github.com/minorua/Qgis2threejs) but I am more interested in
>> > working with the native 3D handling of QGIS.
>> > Thanks in advance
>> > Abdelghani TAMORT
>> > _______________________________________________
>> > QGIS-Developer mailing list
>> > QGIS-Developer at lists.osgeo.org
>> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Johannes Kröger / GIS-Entwickler/-Berater
>> Aufwind durch Wissen!
>> Web-Seminare und Online-Schulungen
>> bei der www.foss-academy.com
>> WhereGroup GmbH
>> c/o KK03 GmbH
>> Lange Reihe 29
>> 20099 Hamburg
>> Germany
>> Tel: +49 (0)228 / 90 90 38 - 36
>> Fax: +49 (0)228 / 90 90 38 - 11
>> johannes.kroeger at wheregroup.com
>> www.wheregroup.com
>> Geschäftsführer:
>> Olaf Knopp, Peter Stamm
>> Amtsgericht Bonn, HRB 9885
> Saber Razmjooei
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20240425/7ed23c82/attachment-0001.htm>
