[QGIS-Developer] question
Johannes Kröger (WhereGroup)
johannes.kroeger at wheregroup.com
Thu Apr 25 06:16:33 PDT 2024
Hi Abdelghani,
that blog post highlights new features of version 3.36. Those methods
are not available in 3.34.x. ;)
Cheers, Hannes
On 25.04.24 14:47, Abdelghani Tamort wrote:
> Hi Saber,
> From the link you sent, I tried some code lines. For instance, I tried
> "iface.mapCanvases3D()" but It doesn't seem to work, I'm getting the
> following error: AttributeError: 'QgisInterface' object has no
> attribute 'mapCanvases3D'. I'm working on QGIS 3.34.5.
> Kind regards,
> Abdelghani
> On Fri, 12 Apr 2024 at 15:49, Saber Razmjooei
> <saber.razmjooei at lutraconsulting.co.uk> wrote:
> Hi,
> You can find more code snippet and examples here:
> https://www.lutraconsulting.co.uk/blog/2024/02/05/new-features-in-qgis-36/
> Kind regards
> Saber
> On Fri, 12 Apr 2024 at 11:58, Johannes Kröger (WhereGroup) via
> QGIS-Developer <qgis-developer at lists.osgeo.org> wrote:
> Hi,
> afaik the 3D Python API is not fully finalized yet. But you
> can already
> control some aspects of it from Python, mostly the views
> themselves.
> This was added recently, see
> https://github.com/qgis/QGIS/pull/55862
> Have fun!
> Hannes
> On 12.04.24 11:30, Abdelghani Tamort via QGIS-Developer wrote:
> > Hello,
> > I want to post a message (which contains an inquiry) to the
> qgis
> > developer list.
> > The message is the following:
> > Is there a solid documentation/tutorials on handling 3D on
> QGIS's
> > python API ? Currently working on a QGIS plugin that exports
> data in
> > 3D format and trying to make use of the 3D views in QGIS to
> visualize
> > the outputs. I am aware of the Qgis2threejs plugin
> > (https://github.com/minorua/Qgis2threejs) but I am more
> interested in
> > working with the native 3D handling of QGIS.
> > Thanks in advance
> > Abdelghani TAMORT
> > QGIS-Developer mailing list
> > QGIS-Developer at lists.osgeo.org
> > List info:
> https://lists.osgeo.org/mailman/listinfo/qgis-developer
> > Unsubscribe:
> Johannes Kröger / GIS-Entwickler/-Berater
> Aufwind durch Wissen!
> Web-Seminare und Online-Schulungen
> bei der www.foss-academy.com <http://www.foss-academy.com>
> WhereGroup GmbH
> c/o KK03 GmbH
> Lange Reihe 29
> 20099 Hamburg
> Germany
> Tel: +49 (0)228 / 90 90 38 - 36
> Fax: +49 (0)228 / 90 90 38 - 11
> www.wheregroup.com <http://www.wheregroup.com>
> Geschäftsführer:
> Olaf Knopp, Peter Stamm
> Amtsgericht Bonn, HRB 9885
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe:
> Saber Razmjooei
> www.lutraconsulting.co.uk <http://www.lutraconsulting.co.uk>
bei derwww.foss-academy.com
WhereGroup GmbH
c/o KK03 GmbH
Lange Reihe 29
20099 Hamburg
Germany
www.wheregroup.com
Geschäftsführer:
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20240425/930cf0a7/attachment.htm>
