[QGIS-Developer] question
Abdelghani Tamort
abdel.tmrt at gmail.com
Thu Apr 25 06:40:27 PDT 2024
Hi Johannes,
You're right, thanks! Oh and by the way, using the _3d module documentation
of version 3.36 (https://qgis.org/pyqgis/3.36/_3d/index.html) is it
possible to code everything that the GUI offers or some features of the GUI
are not yet implemented in the python API ?
Cheers,
Abdelghani
On Thu, 25 Apr 2024 at 15:16, Johannes Kröger (WhereGroup) <
johannes.kroeger at wheregroup.com> wrote:
> Hi Abdelghani,
> that blog post highlights new features of version 3.36. Those methods are
> not available in 3.34.x. ;)
> Cheers, Hannes
> On 25.04.24 14:47, Abdelghani Tamort wrote:
> Hi Saber,
> From the link you sent, I tried some code lines. For instance, I tried "
> iface.mapCanvases3D()" but It doesn't seem to work, I'm getting the
> following error: AttributeError: 'QgisInterface' object has no attribute
> 'mapCanvases3D'. I'm working on QGIS 3.34.5.
> Kind regards,
> Abdelghani
> On Fri, 12 Apr 2024 at 15:49, Saber Razmjooei <
> saber.razmjooei at lutraconsulting.co.uk> wrote:
>> Hi,
>> You can find more code snippet and examples here:
>> https://www.lutraconsulting.co.uk/blog/2024/02/05/new-features-in-qgis-36/
>> Kind regards
>> Saber
>> On Fri, 12 Apr 2024 at 11:58, Johannes Kröger (WhereGroup) via
>> QGIS-Developer <qgis-developer at lists.osgeo.org> wrote:
>>> Hi,
>>> afaik the 3D Python API is not fully finalized yet. But you can already
>>> control some aspects of it from Python, mostly the views themselves.
>>> This was added recently, see https://github.com/qgis/QGIS/pull/55862
>>> Have fun!
>>> Hannes
>>> On 12.04.24 11:30, Abdelghani Tamort via QGIS-Developer wrote:
>>> > Hello,
>>> > I want to post a message (which contains an inquiry) to the qgis
>>> > developer list.
>>> > The message is the following:
>>> > Is there a solid documentation/tutorials on handling 3D on QGIS's
>>> > python API ? Currently working on a QGIS plugin that exports data in
>>> > 3D format and trying to make use of the 3D views in QGIS to visualize
>>> > the outputs. I am aware of the Qgis2threejs plugin
>>> > (https://github.com/minorua/Qgis2threejs) but I am more interested in
>>> > working with the native 3D handling of QGIS.
>>> > Thanks in advance
>>> > Abdelghani TAMORT
>>> > _______________________________________________
>>> > QGIS-Developer mailing list
>>> > QGIS-Developer at lists.osgeo.org
>>> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> Johannes Kröger / GIS-Entwickler/-Berater
>>> Aufwind durch Wissen!
>>> Web-Seminare und Online-Schulungen
>>> bei der www.foss-academy.com
>>> WhereGroup GmbH
>>> c/o KK03 GmbH
>>> Lange Reihe 29
>>> 20099 Hamburg
>>> Germany
>>> Tel: +49 (0)228 / 90 90 38 - 36
>>> Fax: +49 (0)228 / 90 90 38 - 11
>>> www.wheregroup.com
>>> Geschäftsführer:
>>> Olaf Knopp, Peter Stamm
>>> Amtsgericht Bonn, HRB 9885
>> Saber Razmjooei
> WhereGroup GmbH
> c/o KK03 GmbH
> Lange Reihe 29
> 20099 Hamburg
> Germany
> johannes.kroeger at wheregroup.comwww.wheregroup.com
> Geschäftsführer:
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20240425/3588f19f/attachment-0001.htm>
