[QGIS-Developer] GDAL processing algorithms issues due the default output layer extensions weirdly changed
Abdul Raheem Siddiqui
abdulraheemsiddiqui at gmail.com
Sat Apr 27 15:36:55 PDT 2024
I am the owner of the Curve Number Generator plugin and multiple people
have reported this issue. They are saying they never changed the default
format themselves.
When they make a new profile, everything works well. Someone has reported
this to QGIS as well
https://github.com/qgis/QGIS/issues/57250#issuecomment-2080370076
<https://www.linkedin.com/in/abdulraheemsiddiqui/>
On Thu, Mar 14, 2024 at 12:12 PM Andrea Giudiceandrea via QGIS-Developer <
qgis-developer at lists.osgeo.org> wrote:
> I've recently seen 3 other reports from as many users [1] [2] [3] using
> QGIS 3.36 and QGIS 3.34 about the same issue which completely disrupts
> the functionality of the GDAL processing algorithms.
> Maybe the fix could be to just totally avoid to use the "-1" value as
> the default for the "Default output [vector|raster] layer extension" and
> use the value 0 instead. I don't have enough knowledge of the settings
> logic to propose a fix, anyway I think it would be great if the
> underlying root cause of the issue could be fixed ASAP.
> Best regards.
> [1] https://github.com/qgis/QGIS/issues/56588
> [2]
> https://gis.stackexchange.com/questions/478050/raster-to-vector-bunch-of-errors/
> [3] https://lists.osgeo.org/pipermail/qgis-user/2024-March/054176.html
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20240427/efecf504/attachment.htm>
