[QGIS-Developer] Merge attributes tool and default values
Vedran Stojnović phidrho at gmail.com
Thu Dec 12 10:45:29 PST 2024
Hi Juho,
have you tried enabling/disabling option in project properties: Project >
Properites > Data Sources > Evaluate default values on provider side.
čet, 12. pro 2024. u 10:52 Juho Ervasti via QGIS-Developer <
qgis-developer at lists.osgeo.org> napisao je:
> Hey,
> I'm writing about a QGIS issue https://github.com/qgis/QGIS/issues/59494.
> In summary when using the merge feature tool the attributes for the pending
> new feature are initially populated with a default value for the field if
> one is set in the data provider (e.g. Postgres, OGR). The default value set
> in QGIS doesn't have an effect.
> Is this the intended behavior? At least in some cases it would make sense
> if the value came from the selected features, like it does if a default
> value is not set.
> If it is the intended behavior and shouldn't be changed outright, would it
> be okay to add an option for it in the Attribute form's "Policies" section,
> similar to the splitting and duplicating policies?
> Best regards,
> Juho Ervasti
> GIS Specialist
> Gispo Finland Ltd.
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Srdačan pozdrav / Kind regards,
Vedran Stojnović.
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20241212/86073bb4/attachment.htm>
More information about the QGIS-Developer mailing list
