[QGIS-Developer] Merge attributes tool and default values
    Juho Ervasti
    juho.ervasti at gispo.fi
    Thu Dec 12 23:44:07 PST 2024
Hi Vedran,
Thank you for the suggestion, I didn't consider that, in this case it would
still be desirable to evaluate them elsewhere, just not in the merge
dialog. But I went ahead and tested it and even with that option checked it
still uses the default values, which seems like a bug.
Best regards,
Juho Ervasti
GIS Specialist
Gispo Finland Ltd.
On Thu, Dec 12, 2024 at 8:46 PM Vedran Stojnović <phidrho at gmail.com> wrote:
> Hi Juho,
> have you tried enabling/disabling option in project properties: Project >
> Properites > Data Sources > Evaluate default values on provider side.
> čet, 12. pro 2024. u 10:52 Juho Ervasti via QGIS-Developer <
> qgis-developer at lists.osgeo.org> napisao je:
>> Hey,
>> I'm writing about a QGIS issue https://github.com/qgis/QGIS/issues/59494.
>> In summary when using the merge feature tool the attributes for the pending
>> new feature are initially populated with a default value for the field if
>> one is set in the data provider (e.g. Postgres, OGR). The default value set
>> in QGIS doesn't have an effect.
>> Is this the intended behavior? At least in some cases it would make sense
>> if the value came from the selected features, like it does if a default
>> value is not set.
>> If it is the intended behavior and shouldn't be changed outright, would
>> it be okay to add an option for it in the Attribute form's "Policies"
>> section, similar to the splitting and duplicating policies?
>> Best regards,
>> Juho Ervasti
>> GIS Specialist
>> Gispo Finland Ltd.
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Srdačan pozdrav / Kind regards,
> Vedran Stojnović.
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20241213/e7c9eb0c/attachment-0001.htm>
