[QGIS-Developer] pre-commit for code-formatting
Denis Rouzaud denis.rouzaud at gmail.com
Thu Dec 12 13:34:54 PST 2024
Le jeu. 12 déc. 2024, 22:22, Stefanos Natsis <uclaros at gmail.com> a écrit :
> I also don't like the commit bot.
> I've already had to force push, which I don't like to as it usually
> disturbs reviewing, because it committed a change even though pre-commit
> was ran locally!
> https://github.com/qgis/QGIS/pull/59790/commits/4fc5d7011b8dbb234850f7147b69825d275f6f66
Clang-format was added to gui after the last commit of your head branch but
before you created the pull request. So this is due to the transition and
won't happen again.
> Stefanos
> On Thu, 12 Dec 2024 at 21:41, Denis Rouzaud via QGIS-Developer <
> qgis-developer at lists.osgeo.org> wrote:
>> I would argue in favor of the auto update:
>> * it's easier for newcomers: having a pull request rejected because of
>> indentation is not welcoming
>> * it's easier for online editing
>> * the argument that you need to rebase is not valid to me:
>>     * you can always force push and the code beautifier will be run on
>> top again
>>     * the solution you mention is to have an environment properly set up:
>> if you do so, you won't have pre-commit commits in the log
>> Le jeu. 12 déc. 2024 à 16:53, Jean Felder via QGIS-Developer <
>> qgis-developer at lists.osgeo.org> a écrit :
>>> Le 12/12/2024 à 16:38, Even Rouault via QGIS-Developer a écrit :
>>> > Le 12/12/2024 à 16:33, Julien Cabieces via QGIS-Developer a écrit :
>>> >> Not a great fan of this approach, It looks like complicated to me, I
>>> would prefer the old behavior.
>>> >> Those automatic PR force also contributor to rebase before pushing new
>>> >> modification to their branch. And if they have modified area of code
>>> >> which have been reformatted, they get conflicts.
>>> >> automatic pre-commit commits brings more difficulties than what it
>>> >> solves IMHO.
>>> > I also tend to agree on that. On other projects I'm involved too
>>> > (GDAL, PROJ, shapelib, libtiff) where we have put in place pre-commit,
>>> > we just have a CI check that checks the formatting is OK. This
>>> > requires a bit of education to first time contributors, but pointing
>>> > to the documentation with clear instructions on how to setup
>>> > pre-commit should be good enough.
>>> https://github.com/qgis/QGIS/edit/master/.github/PULL_REQUEST_TEMPLATE.md
>>> > could also have some words about it
>>> > Like in
>>> https://github.com/OSGeo/gdal/edit/master/.github/PULL_REQUEST_TEMPLATE.md
>>> > , " - [ ] Make sure code is correctly formatted (cf [pre-commit
>>> > configuration](
>>> https://gdal.org/development/dev_practices.html#commit-hooks))"
>>> On second thoughts, I agree with Julien and Even.
>>> Jean
>>> QGIS-Developer mailing list
>>> QGIS-Developer at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20241212/d7cd0f94/attachment.htm>
More information about the QGIS-Developer mailing list
