[QGIS-Developer] pre-commit for code-formatting
Denis Rouzaud
denis.rouzaud at gmail.com
Thu Dec 12 23:17:44 PST 2024
Le jeu. 12 déc. 2024 à 22:48, Stefanos Natsis via QGIS-Developer <
qgis-developer at lists.osgeo.org> a écrit :
> > seems good now? Do you have a pointer to a failing workflow?
> > I fixed an invalid regex in prepare_commit 2 days ago, so hopefully
> > everything is ok now.
> Seems fixed indeed :)
> > you must choose with or without apparently in clang-format
> Apparently, the online configurator you linked stops at version 10.
> Starting with v13, clang format also allows SpacesInAngles=Leave
> Could we use this or do we need to support older versions?
here you go https://github.com/qgis/QGIS/pull/59879
> > > 5. Similar for SpacesInSquareBrackets and SpacesInContainerLiterals
> > same
> I believe setting those two to true would be more in line with the rest of
> the style, which favors whitespaces, no?
> Maybe I'll just have to get used to it :)
> Any news on the multi line parameters improvement?
oops I had a mail in draft but did not follow-up
here is what I found:
https://stackoverflow.com/questions/39779985/how-to-control-clang-format-indentation-of-chained-method-calls
I've set a bounty but it didn't seem to attract attention :(
I don't see any solution for the moment now.
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20241213/7c15d2e3/attachment.htm>
