[QGIS-Developer] Warning: auto-transaction groups is broken for recent GDAL versions
Even Rouault
even.rouault at spatialys.com
Mon Dec 16 16:59:03 PST 2024
It is *partly* broken, that is if you change the structure of tables by
adding/altering/removing columns. within a transaction group. If
adding/updating/deleting features only, which I suspect covers most use
cases, that should be fine.
Le 17/12/2024 à 00:11, Nyall Dawson via QGIS-Developer a écrit :
> Hi list,
> Just want to draw attention to
> https://github.com/qgis/QGIS/pull/59797#issuecomment-2544133498 . In
> short, the "auto transaction group" functionality is BROKEN when used
> with sqlite/geopackage files when used with newer GDAL versions.
> This IS NOT a GDAL issue, but rather just a "happy accident" that this
> functionality ever worked (QGIS is misusing GDAL API for this
> feature).
> There's a non-trivial amount of work to do in refactoring this feature
> to get it working again. If you're interested in seeing this
> functionality fixed, please read the above linked thread for all the
> diagnostic work that Even and myself have already done and hints on
> how it could possibly be fixed.
> Accordingly, in https://github.com/qgis/QGIS/pull/59910 I propose to
> disable the corresponding test, which is currently blocking upgrading
> CI infrastructure to newer Ubuntu/Fedora releases.
> Nyall
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
http://www.spatialys.com
Butcher of all kinds of standards, open or closed formats. At the end, this is just about bytes.
