[QGIS-Developer] Warning: auto-transaction groups is broken for recent GDAL versions
Alessandro Pasotti apasotti at gmail.com
Mon Dec 16 23:39:47 PST 2024
Can/should we fix it upstream in GDAL?
On Tue, Dec 17, 2024 at 2:12 AM Even Rouault via QGIS-Developer <
qgis-developer at lists.osgeo.org> wrote:
> It is *partly* broken, that is if you change the structure of tables by
> adding/altering/removing columns. within a transaction group. If
> adding/updating/deleting features only, which I suspect covers most use
> cases, that should be fine.
> Le 17/12/2024 à 00:11, Nyall Dawson via QGIS-Developer a écrit :
> > Hi list,
> > Just want to draw attention to
> > https://github.com/qgis/QGIS/pull/59797#issuecomment-2544133498 . In
> > short, the "auto transaction group" functionality is BROKEN when used
> > with sqlite/geopackage files when used with newer GDAL versions.
> > This IS NOT a GDAL issue, but rather just a "happy accident" that this
> > functionality ever worked (QGIS is misusing GDAL API for this
> > feature).
> > There's a non-trivial amount of work to do in refactoring this feature
> > to get it working again. If you're interested in seeing this
> > functionality fixed, please read the above linked thread for all the
> > diagnostic work that Even and myself have already done and hints on
> > how it could possibly be fixed.
> > Accordingly, in https://github.com/qgis/QGIS/pull/59910 I propose to
> > disable the corresponding test, which is currently blocking upgrading
> > CI infrastructure to newer Ubuntu/Fedora releases.
> > Nyall
> > QGIS-Developer mailing list
> > QGIS-Developer at lists.osgeo.org
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> http://www.spatialys.com
> My software is free, but my time generally not.
> Butcher of all kinds of standards, open or closed formats. At the end,
> this is just about bytes.
Alessandro Pasotti
QCooperative:  www.qcooperative.net
ItOpen:   www.itopen.it
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20241217/e3a481e3/attachment-0001.htm>
More information about the QGIS-Developer mailing list
