[QGIS-Developer] Warning: auto-transaction groups is broken for recent GDAL versions
Andreas Neumann andreas at qgis.org
Mon Dec 16 23:53:12 PST 2024
If we can find a developer who could work on this then we can fund it
directly from QGIS.ORG.
We had so far quite a bit more income than expenses in 2024 and I am
looking for meaningful ways to spend additional QGIS funds.
Thanks,
Andreas
On Tue, 17 Dec 2024 at 08:40, Alessandro Pasotti via QGIS-Developer <
qgis-developer at lists.osgeo.org> wrote:
> Can/should we fix it upstream in GDAL?
> On Tue, Dec 17, 2024 at 2:12 AM Even Rouault via QGIS-Developer <
>> It is *partly* broken, that is if you change the structure of tables by
>> adding/altering/removing columns. within a transaction group. If
>> adding/updating/deleting features only, which I suspect covers most use
>> cases, that should be fine.
>> Le 17/12/2024 à 00:11, Nyall Dawson via QGIS-Developer a écrit :
>> > Hi list,
>> > Just want to draw attention to
>> > https://github.com/qgis/QGIS/pull/59797#issuecomment-2544133498 . In
>> > short, the "auto transaction group" functionality is BROKEN when used
>> > with sqlite/geopackage files when used with newer GDAL versions.
>> > This IS NOT a GDAL issue, but rather just a "happy accident" that this
>> > functionality ever worked (QGIS is misusing GDAL API for this
>> > feature).
>> > There's a non-trivial amount of work to do in refactoring this feature
>> > to get it working again. If you're interested in seeing this
>> > functionality fixed, please read the above linked thread for all the
>> > diagnostic work that Even and myself have already done and hints on
>> > how it could possibly be fixed.
>> > Accordingly, in https://github.com/qgis/QGIS/pull/59910 I propose to
>> > disable the corresponding test, which is currently blocking upgrading
>> > CI infrastructure to newer Ubuntu/Fedora releases.
>> > Nyall
>> > _______________________________________________
>> > QGIS-Developer mailing list
>> > QGIS-Developer at lists.osgeo.org
>> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> http://www.spatialys.com
>> My software is free, but my time generally not.
>> Butcher of all kinds of standards, open or closed formats. At the end,
>> this is just about bytes.
> Alessandro Pasotti
> QCooperative:  www.qcooperative.net
> ItOpen:   www.itopen.it
Andreas Neumann
QGIS.ORG board member (treasurer)
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20241217/08c07033/attachment.htm>
More information about the QGIS-Developer mailing list
