[QGIS-Developer] Compilation error during cmake configuration
Paul N
surveykshak at gmail.com
Sun Feb 11 17:00:22 PST 2024
Thanks for the reply.
Paul N
On Mon, 12 Feb, 2024, 12:06 am Matthias Kuhn, <matthias at opengis.ch> wrote:
> Hi,
> This is introduced by https://github.com/qgis/QGIS/pull/56284.
> It looks like the Qt5Keychain cmake config contains paths from the system
> where it was built originally.
> Ideally this should be fixed in the Qt5Keychain package of OSGeo4W.
> If this is not possible, we'll probably have to re-add a small wrapper
> cmake script to fix the find logic specifically for OSGeo4W.
> Right now the easiest workaround for you is probably to just revert this
> commit.
> Kind regards
> Matthias
> On Sun, Feb 11, 2024 at 11:32 AM Paul N via QGIS-Developer <
> qgis-developer at lists.osgeo.org> wrote:
>> Hi,
>> During cmake-gui configuration on windows 10, I am getting this error on
>> master branch compilation.
>> CMake Error at
>> C:/OSGeo4W/apps/Qt5/lib/cmake/Qt5Keychain/Qt5KeychainLibraryDepends.cmake:73
>> (message):
>> The imported target "qt5keychain" references the file
>> "D:/src/osgeo4w/src/qtkeychain/osgeo4w/install/apps/Qt5/lib/qt5keychain.lib"
>> but this file does not exist. Possible reasons include:
>> * The file was deleted, renamed, or moved to another location.
>> * An install or uninstall procedure did not complete successfully.
>> * The installation package was faulty and contained
>> "C:/OSGeo4W/apps/Qt5/lib/cmake/Qt5Keychain/Qt5KeychainLibraryDepends.cmake"
>> but not all the files it references.
>> Call Stack (most recent call first):
>> C:/OSGeo4W/apps/Qt5/lib/cmake/Qt5Keychain/Qt5KeychainConfig.cmake:35
>> (include)
>> CMakeLists.txt:574 (find_package)
>> On other branches, compilation i.e 3.34.3 is not giving any error. Any
>> fix for this?
>> Regards
>> Paul P
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20240212/45c650fc/attachment.htm>
