[QGIS-Developer] Could not execute: INSERT INTO tbl_sr during ninja install
Paul N surveykshak at gmail.com
Fri Feb 16 05:11:55 PST 2024
QGIS compilation successful with *build ninja* on windows 10. While trying
to install using *ninja install*, I am getting the following error message.
There are many rows like below, few of them are below which also have the
last line.
Could not execute: INSERT INTO tbl_srs(srs_id,
description,projection_acronym,ellipsoid_acronym,parameters,srid,auth_name,auth_id,is_geo,deprecated,srs_type)
VALUES (64078, 'Neptune (2015) / Ographic /
Mercator','merc','merc','+proj=merc +R_C +lat_0=0 +lon_0=0 +x_0=0 +y_0=0
+a=24764000 +b=24341000 +units=m
+no_defs',520004078,'IAU_2015','89991',0,0,'Projected') [UNIQUE constraint
failed: tbl_srs.srs_id/UNIQUE constraint failed: tbl_srs.srs_id]
VALUES (64079, 'Neptune (2015) / Ocentric /
+no_defs',520004079,'IAU_2015','89992',0,0,'Projected') [UNIQUE constraint
VALUES (64080, 'Charon (2015) - Sphere / Ocentric /
+R=606000 +units=m +no_defs',520004080,'IAU_2015','90190',0,0,'Projected')
[UNIQUE constraint failed: tbl_srs.srs_id/UNIQUE constraint failed:
tbl_srs.srs_id]
VALUES (64081, 'Gaspra (2015) - Sphere / Ocentric /
+R=6100 +units=m
+no_defs',520004081,'IAU_2015','951101090',0,0,'Projected') [UNIQUE
constraint failed: tbl_srs.srs_id/UNIQUE constraint failed: tbl_srs.srs_id]
VALUES (64082, 'Pluto (2015) - Sphere / Ocentric /
+R=1188300 +units=m +no_defs',520004082,'IAU_2015','99990',0,0,'Projected')
tbl_srs.srs_id]
*522 CRSs could not be updated.*
Any clue?
Regards
Paul N
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20240216/f613fd60/attachment.htm>
More information about the QGIS-Developer mailing list
