[QGIS-Developer] Could not execute: INSERT INTO tbl_sr during ninja install
Andrea Giudiceandrea
andreaerdna at libero.it
Fri Feb 16 08:18:26 PST 2024
Il 16/02/2024 14:11, Paul N via QGIS-Developer ha scritto:
> Could not execute: INSERT INTO tbl_srs(srs_id,
> description,projection_acronym,ellipsoid_acronym,parameters,srid,auth_name,auth_id,is_geo,deprecated,srs_type) VALUES (64078, 'Neptune (2015) / Ographic / Mercator','merc','merc','+proj=merc +R_C +lat_0=0 +lon_0=0 +x_0=0 +y_0=0 +a=24764000 +b=24341000 +units=m +no_defs',520004078,'IAU_2015','89991',0,0,'Projected') [UNIQUE constraint failed: tbl_srs.srs_id/UNIQUE constraint failed: tbl_srs.srs_id]
Hi Paul N,
it looks like that issue happens from time to time. Anyway I suppose
such issue may have been already fixed. See
https://github.com/qgis/QGIS/pull/56317/commits/aa7317e4239e88252c3327bcccd27646062087aa
Which commit are have you build on?
Best regards.
Andrea
